Help a rookie fill the tranny
Old Oct 18, 2008 | 12:58 PM
Shroken's Avatar
Car: '85 Trans Am
Engine: 350 Crate Motor
Axle/Gears: 3.27 posi
still learning how to use the searches on this and found what I need
Last edited by Shroken; Oct 18, 2008 at 01:22 PM. Reason: hadn't had my rockstar when I posted
Old Oct 18, 2008 | 01:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Help a rookie fill the tranny
sounds like a vent tube
Double check this first because in not totally sure, but on the passengerside of the trans there is a threaded plug that you remove to add the fluid. There apparently is another threaded plug looking thing on the trans that holds internal parts together, remove it and your f-ed and have to pull the trans, i believe this plug is on the driverside but im not a 100% on that.
Old Oct 18, 2008 | 01:33 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
DO NOT remove the torx bolt on the driver side. If you do you will definitely regret it.
The fill/drain plugs are both on the passengers side of the car.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
meeklay812
Oct 1, 2015 03:46 PM
TheExaminer
Sep 6, 2015 11:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
