What gears in a 83 5 speed 305 with rear discs??
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Hello i found a "sledged" car in a JY. It was a 305 5speed with rear discs. What gears would be in the rear end? no rpos so thats no help. I might be switching from my aluminum drums to these discs. Any thoughts?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: What gears in a 83 5 speed 305 with rear discs??
Not enough information however according to the TGO database;
A 1983 with a 305 and manual transmission usually has 3.23 gears. If it has a G92 RPO code or the car is a Z28 with a 4bbl HO engine, it will have 3.73 gears. Without an RPO list, the only way to know for sure is to pull the cover and look inside.
Car: 89 IROC-Z
Thanks alot Stephen. Im pretty sure the car was a z28, it had a fiberglass hood. Ill go there and pull the cover off to count teeth. Im hopeing its the 3:23, I have 3:08 gears now, so hopefully the 3:23s would give it a little more push. 3:73s might be a bit much for highway use. What is your opinion on the 373s for highway? Ill do a search
OK it looks like the 373s will make me run 18% higher rpms, while the 323s will be only a 5% increase in rpms. Hmmm maybe some 3.45s or something. 373s are out of the question as i do mostly highway cruiseing, but want a little more around town.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check to see if the vin is "G," which would make it an L69 (305HO) and, probably, a 3.73 car. A vin "H" car would probably be 3.23. As Steven mentions, however, only pulling the cover will provide the truth.
JamesC
JamesC
Car: 89 IROC-Z
Thanks James, the only problem is there is no car, they crushed it. But they saved the rear out of it. I can get a disc disc proportioning valve from another car though. The only way i know what the car looked like was this. https://www.thirdgen.org/forums/hist...tory-some.html yea its the same car. I know its locked Scottmoyer but i just want to show it to get help on this subject.
Car: 87 IROC L98
There should also be an axle code. Stamped on the front of the passenger side tube close to the center of the diff will be a code. It's normally difficult to find and read because of dirt, rust and light stamping. That will tell you what was originally inside the diff.
Car: 89 IROC-Z
Thanks for all the info guys, When i get that plate off ill know for sure.
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
I ordered my car with 3.73 gears, no posi. I had the original .94 (I think thats right) overdrive T-5 and 215/65s so on the highway it ran really nice. About 2200,2300 at normal speed limits. Lots of snap off the start and good highway runout. I later installed a WC T-5 with deeper OD and similiar 1,2,3,4 gears, which netted a loafing 1900 at 55mph. Stock it got 21 mpg combined driving average.
Car: 83Z28 HO
Transmission: G Force 5 speed
If it's an '83, you won't find a "G" VIN. It'll be a "7" VIN if it's an HO L69 car. I'm guessing it's not since it has disc brakes though. The vast majority of the HO cars in '83 came with one-legger 3.73's with aluminum drums...(first year of the L69 option)
hectre13
Dec 11, 2023 08:14 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
