Grinding into second
Old Feb 14, 2001 | 12:01 PM
Mikes91bird's Avatar
My T-5 grinds when I go into second, the dealer said something about the clutch, but a friend of mine who has had a few 3rg gen camaros says that it is the linkage. What do you guys think... Lemme know...
Old Feb 14, 2001 | 02:32 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
My T5 was grinding going into 2nd gear, and it was the 2nd gear itself, and the 2nd gear synchros that needed to be replaced.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Feb 14, 2001 | 11:27 PM
<font face="Verdana, Arial" size="2">Originally posted by Kevin91Z:
</font>
About how much did it cost to fix it?
Old Feb 15, 2001 | 01:32 AM
Kevin91Z's Avatar
I'm not a good person to ask, as my dad is a mechanic and I get cheap labor and parts for his cost. I'd say its expensive tho, especially if they have to pull the trans. If you pull it and bring it to them, you'd save a lot of the cost.
Old Feb 15, 2001 | 10:39 AM
I was afraid you would say that... Thanks for the help.
Mike
Old Feb 15, 2001 | 11:39 PM
82z's Avatar
82z
How could the linkage or clutch effect 2nd but not any of the other gears? Both of those problems would effect all the gears. I think your problem is the 2nd gear synchro.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Jorlain
Oct 8, 2015 01:57 AM
hdis2002
Sep 8, 2015 02:52 PM
solocus
Sep 2, 2015 12:14 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
hokis
Aug 9, 2015 03:57 PM
