Tranny not working after install
Old Oct 22, 2008 | 05:17 PM
91_z28_guy's Avatar
Car: 91 CAMARO Z28
Engine: 5.8L TPI 355 L98
Ok i just installed my transmission back into my 91 z 700R4 and it was out of the car for about 8 months. Now thats everythings back together and the car is running, when i put the car into gear it does nothin. But i did take it and put it on jack stands and the wheels turn slowly but no pressure. FLuid is good and i believe that i installed the torque converter correctly. Any help is greatly appreciated.
Old Oct 22, 2008 | 05:32 PM
skinny z's Avatar
Re: Tranny not working after install
Could be a number of things. I'm no transmission expert however there are a few things that could have been messed up during the install.
Trans filter and/or filter o-ring.
Torque convertor pump drive not fully engaged into pump housing. ( Was the convertor easily aligned and bolted to the flex plate or did you draw it in using the bolts? )
Was the trans rebuilt or modified during the time it was removed?
Old Oct 23, 2008 | 08:03 AM
91_z28_guy's Avatar
Car: 91 CAMARO Z28
I didnt do anything with the filter. And as for the convertor it went in quite easy and no i didnt have to align the holes with the bolts. Also there was no modifying done to the tranny while it was out.
Old Oct 23, 2008 | 08:28 AM
skinny z's Avatar
TV cable and adjustment?
Debris or dirt in the cooler lines ( from when the trans was out )
Does the condition exist in all gears?
Old Oct 23, 2008 | 09:55 AM
91_z28_guy's Avatar
Car: 91 CAMARO Z28
By TV cable do u mean shift cable? And yes there could have be dirt in the cooler lines but what would the fix for that be now? And yes i have that problem in every gear i get nothing when its on the ground 1,2,d,od,r everything.
Old Oct 23, 2008 | 10:10 AM
skinny z's Avatar
Since you have the problem in all gears it would seem to me that it's something basic.
The TV cable connects the throttle positon at the TPI throttle body to the trans. The shift cable typically describes the shifter to trans cable ( for gear selection )
I know you've checked the obvious: fluid level ( hot and in park ), the TV cable ( not the shifter cable ) has a very precise adjustment, torque convertor fully engaged into the transmission pump housing,
It seems that you're not developing any fluid pressure. A plugged trans line could give you that problem although unlikely. ( disconnect the lines from the trans and blow out the lines and cooler with compressed air).
Beyond these suggestions, I'm at a loss.
Somehow I'm suspicious about the TV cable adjustment.
Old Oct 23, 2008 | 11:02 AM
91_z28_guy's Avatar
Car: 91 CAMARO Z28
Ok im going to get right on that stuff, i appreciate all your help and will let you know what happens.
Old Oct 23, 2008 | 06:49 PM
Steve86TA's Avatar
Car: To many to list
Are you sure you have the converter engauged on the pump all the way?You should spin the conveter while pushing it in and you will fell it fall in place and spin it some more and it will fully engauge.It could have dis-engauged during installation.
The TV cable has nothing to do with it moving in gear.That has more to do with the shifts/shiftpoints
Old Oct 24, 2008 | 08:25 AM
91_z28_guy's Avatar
Car: 91 CAMARO Z28
Yea thats the thing i was thinking about because when i checked to cable yesturday it was fine and i said to myself that has nothing to do with it going into gear. I think i turned the convertor only 1 round before i put it back in so that could very well be the problem. Guess its coming back out...
Old Oct 24, 2008 | 08:59 AM
skinny z's Avatar
[QUOTE=skinny z;3925763]
QUOTE]
Like I had asked earlier.
Don't forget the lock tight.
Here's hoping it's that simple.
Keep us posted.
Vintageracer
Jan 10, 2020 05:33 PM
camaro11j
Sep 19, 2018 08:49 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
drathaar907
Aug 6, 2015 04:20 PM
