Where to put trans cooler?
Old Feb 8, 2001 | 08:38 PM
Josh91Bird's Avatar
Car: 1991 Firebird
Engine: 412ci/sb
Transmission: Built 700R4
Where have you guys installed your trann coolers? Where would you suggest is the best spot to mount one? Thanks
91 Firebird 305/TBI - cam:.420/.442 204/214 - Hooker 1 5/8" headers - TFX PaceSetter Cat-Back - 3.42's Auburn Pro Posi - ASCD Ram-Air hood - Polished Formula Wheels w/Futura's - Open element - .5" Corian TB spacer - Lakewood LCA's - Hotchkis Lowering Springs - KYB Struts/Shocks - 14.78 @ 97.5 mph(G-Tech) - MacEwen MotorSports Whiteface Overlays - 412ci sb waiting to go in this spring.
My Homepage
Old Feb 8, 2001 | 08:52 PM
MrJ's Avatar
MrJ
The best spot by far is right over the air dam, in front of the condensor. It can sit on that lip on the radiator/condensor shelf.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
Old Feb 8, 2001 | 08:53 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
I put mine in front of the radiator more to the pass side. I have no A/C so the condenser isn't a prob. It should go before the radiator though.
Old Feb 8, 2001 | 09:17 PM
ede's Avatar
ede
i welded 2 pieces of angle steel to the top and bottom radiator supports and bolted the cooler to it.
ICON Motorsports
1st & 3rd
Old Feb 13, 2001 | 01:29 PM
Desert86Roc's Avatar
Here is mine:
Mike Metzler (Desert86Roc)
Mike@SpeedworldMotorplex.com
[*] Webmaster: SpeedWorldMotorplex.com[*] Click Here For My Racing Page[*]86 IROC 305 TPI (406 build in progress)
ET's @ 1250 ft[*] 14.28 @ 95.461 mph (uncorrected, NOS, no headers)[*] 15.365 @ 86.785 mph (uncorrected, Headers, no NOS)
Old Feb 13, 2001 | 02:57 PM
a73camaro's Avatar
When plumbing the cooler, use the tranny cooler in conjunction with the stock radiator converter.
Make sure that the finned cooler is downstream from the factory radiator cooler. I never remember which line is supply and return, so I undo one, start the car real quick and see which one leaked fluid.
Old Feb 13, 2001 | 04:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
<font face="Verdana, Arial" size="2">Originally posted by a73camaro:
Make sure that the finned cooler is downstream from the factory radiator cooler.</font>
The aftermarket cooler should be installed in the fluid path before the factory cooler, not after it.
Old Feb 15, 2001 | 02:46 PM
Nope...everyone recommends putting the auxiliary cooler in the RETURN line after the factory cooler. In the summertime, the radiator tends to heat your tranny fluid even more, so you want some way to scrub out that extra heat (my theory). My tranny people actually refused to plumb a good cooler before the radiator because the "temperature drop to the fluid would be too much", whatever they meant by that.
Old Feb 16, 2001 | 11:57 PM
a73camaro's Avatar
Desert86Roc has got it right - tranny fluid into the radiator (usually knocks some temperatue down in the tranny fluid) then into the finned exchanger.
Look at the heat transfer medium. Air temperature is WAY cooler than warmed up engine coolent.
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
TreDeClaw
Aug 14, 2015 06:58 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
