trans question?
Old Oct 24, 2008 | 09:03 PM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
trans question?
Car is a 1988 camaro with a 305tpi/700r4. So it started with the trans shifting kinda hard from 1-2. Then it lost 3-4. It would go it second and when it was about to shift into third it was like it hit neutral. So We put another used trans out of an 1989 camaro 305tpi. Took it for a test drive and it did the same thing. Only would shift from 1-2. Any ideas on what it could be? I know its possible to have two bad trans, but is there anything else that would cause this? Any help would be great! Thanks!
Old Oct 24, 2008 | 09:32 PM
Car: 94 25th TA
Engine: 355LT1
Re: trans question?
We also used the same torque converter. I was just told that could be the problem. Something about it not locking up? Does that sound like it could be the problem?
Old Oct 26, 2008 | 12:57 PM
Car: 94 25th TA
Engine: 355LT1
Re: trans question?
Any ideas?
Old Oct 27, 2008 | 11:20 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: trans question?
the converter's lockup feature isn't a factor. I've ruined a half dozen 700R-4s, each in a different way, never intentional, and never had this particular issue
I'd ask about your TV cable adjustment, but then I'd wonder how the issue developed in the first place.
Old Oct 28, 2008 | 01:39 PM
Car: 94 25th TA
Engine: 355LT1
Re: trans question?
Thanks for the reply! We adjusted the TV cable so I would assume thats ok. This is my buddys car so I can't tell you exactly how hes been driving, but he said the first time it happened it was during ordinary driving. Not sure if thats true, but thats what he said.
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
