Early th700r-4 upgrades
Old Oct 25, 2008 | 07:38 PM
Rok_Stars_Bars's Avatar
Car: 1987 Camaro
Engine: Oldsmobile 455
Transmission: Th-700r-4
I have a 1983 Th-700r4 I recently brought it used... I put a trans go shift kit it and filter hoping it work has the PO said it worked. But it looks like Im goin to have to rebuild it. While Im rebuilting it. What do I or can I replace to make it better. Like can I convert it to the 30 spline pump...ect...
Old Oct 26, 2008 | 02:05 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: Early th700r-4 upgrades
Probably be easier to find a later tranny. But you can upgrade to the newer parts tho. There is alot more to consider than just the pump tho.
Old Oct 26, 2008 | 08:04 AM
Car: 1987 Camaro
Yeah... Your right. I looking into getting a newer style on craigslist
Old Oct 30, 2008 | 11:00 AM
Pro Built Automatics's Avatar
Go with a 1988 & up unit, the later the better. Dana
Old Oct 30, 2008 | 09:09 PM
Car: 1987 Camaro
Im picking up a 90 th700r4 (by id number) tommarrow came out of a 1988 s-15 with 4.3L. it was removed a month ago and was driving perfect before till. So all I can do is hope.
Old Oct 31, 2008 | 01:35 AM
Mikz86TA's Avatar
Talk 2 Dana about the V6 tranny vs the V8. 4.3 will have the correct bellhousing, but you will want to update it either way
Old Oct 31, 2008 | 08:52 PM
Car: 1987 Camaro
Whats wrong with the 4.3 version. It 30 spline right? and it bolts up?. the number on the side is 0SHM047H. I believe that is right.
Old Nov 2, 2008 | 07:43 AM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
i think fewer clutches but i may be rong
Old Nov 2, 2008 | 08:40 PM
Car: 1987 Camaro
ok then I can see that. But still no biggie right with a good rebuild kit?
Old Nov 2, 2008 | 08:46 PM
Stephen's Avatar
Car: 87 GTA
I thought the better 700R4s started in 87? Meaning...87 & up...
Old Nov 3, 2008 | 05:10 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
That's what I thought too. Oh well, it's not like my 305 really stresses my 700r4. lol
Old Nov 4, 2008 | 05:09 AM
The reason I state 1988 and up is that most of the 1987's were still using the early valve bodies. If you want to know if you have an early valve body on a 1987, is look on the separator plate at the large rectangular window hole at the rear of the separator plate. You will find a two letter code. If the first letter is an "A", it is an early valve body style, which is ok for Heavy Duty but not for Street/Strip. If the letter is a "B", which is a late 1987 early 1988, it is fine any type of build. Dana
Old Nov 4, 2008 | 09:31 PM
Jammin'Trey's Avatar
haha put a front and rear seal in it
Old Nov 4, 2008 | 10:40 PM
Car: 1987 Camaro
Installed TODAY... Drives great. I love the overdrive and the lower first gear hehe compare to the th-350.
Linson
Oct 24, 2025 02:00 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
Z28/ZR1
Oct 23, 2015 01:04 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
Zell1luk
Sep 29, 2015 10:36 AM
