TA rear cover fill hole?
Old Oct 26, 2008 | 08:43 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Im replacing my gasket of my TA cover cause of a leak....I drained the fluid and it still looks clean so im gonna reuse it...
my question is, theres a fill hole on the top of the cover....do I fill to that point or the normal fill hole on the side of the housing? or does it matter?
is to much fluid a bad thing?
Old Oct 26, 2008 | 09:47 PM
ssean92's Avatar
Car: sold
Re: TA rear cover fill hole?
good question, I still use the fill hole on the side of the rear like normal to deside full
Old Oct 26, 2008 | 10:17 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
you can use the top hole on the cover to fill, but only fill to the normal depth of the original hole
Old Oct 27, 2008 | 06:45 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Question..Why are you going to reuse the old fluild??? Just because it looks clean dose not mean it should not be replaced. All that work and you don't use new fluid... DUMB
Old Oct 27, 2008 | 07:08 AM
big gear head's Avatar
If you want to use the hole in the cover to fill it just remove the plug in the side and fill until the oil runs out the side. Do not fill to the hole in the cover.
Old Oct 27, 2008 | 02:00 PM
ssean92's Avatar
Car: sold
wow looks like you got the awnser a few time
Old Oct 27, 2008 | 03:56 PM
LOL..yeah I guess I did.
another question? I forgot how much torque to put on the cap bolts...I think its like 5 or 10 lbs....and the outter bolts are like 30 or so?
anyone know?
Old Oct 27, 2008 | 05:24 PM
I have the instructions out in the shop, but I'm pretty sure that the preload bolts are 5 foot pounds and the others are 25. I can look it up later if you want. Be sure to use some sealant around the preload bolts to keep oil from leaking out around them. I usually torque them and then use a little RTV around the bolt before putting the jamb nut on.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
I'llrocya
Feb 2, 2016 11:43 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
