1990 RS 305 clunking sound
Old Oct 27, 2008 | 10:17 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
I hope that I am posting this in the right section of the forums, so anyway I have a 1990 Camaro RS with a 5.0 V8 and it makes this clunking sound that I believe has gotten worse. It makes the sound if you're driving and you either brake really hard or if you're just braking normally and you come to a stop and as you near the stop it starts clunking multiple times, it sounds like it's coming from somewhere around the drive shaft, like right under the stick. It also makes the sound if you're driving and you shift poorly, like if you put it in the next gear and let off the clutch without giving it any gas. Other than that it only makes the sound if you stall the car, it starts clunking and jolting violently and dies. Can someone tell me what this could be? It's annoying and it sounds like it is probably causing more damage.
Old Oct 28, 2008 | 06:49 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 1990 RS 305 clunking sound
Welcome to TGO. Check the transmission mount.
JamesC
Old Oct 28, 2008 | 07:40 AM
jeffcj's Avatar
JamesC
Sounds like the classic worn out transmission mount.
Old Oct 28, 2008 | 11:42 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Tranny mount.
Old Oct 30, 2008 | 03:31 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Ah alright, that makes sense, where is it located? Is it difficult to replace?
Old Oct 30, 2008 | 05:14 PM
JamesC's Avatar
Between the tail shaft of the trans and the cross member. Jacking the car up will take nearly as long as replacement. Basic hand tools. I suggest poly.
JamesC
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
gta90
Sep 15, 2015 04:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
Sanjay
Aug 12, 2015 03:41 PM
BlackBoulder
Aug 11, 2015 11:15 PM
