need help w/ 700-r4
Old Feb 16, 2001 | 07:35 PM
Z28IROC350's Avatar
need help w/ 700-r4
What causes my trans not to shift from 2-3 when racing it ? it won't shift till I let it wind back down to around 3-3500 rpms. And what makes it downshift hard in D when coming to a stop ? The track's almost open and I need this fixed ! HELP
if you can't fu@k it or race it, it ain't worth havin' !
Old Feb 16, 2001 | 09:49 PM
82z's Avatar
82z
What are the EXACT conditions when the problems happen?
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Feb 17, 2001 | 01:50 AM
The ODB's Avatar
sounds like a problem with your TV cable.
Old Feb 18, 2001 | 03:34 PM
Z28IROC350's Avatar
I know it's not my TV cable. It only does it every 2 or 3 times I race it. But instead of switching to 3rd, it just keeps winding up in 2nd until i let it wind back down to about 3k rpms (and the other guy goes flyin' by)
Old Feb 18, 2001 | 03:52 PM
The ODB's Avatar
sounds like a problem with your TV.
could also be a sticking shift valve in the valvebody.
[This message has been edited by The ODB (edited February 18, 2001).]
Old Feb 19, 2001 | 09:25 PM
lizzardking's Avatar
early 80's 700R4 are know to be full of problems.
so there may be nothing you can do about it.
Old Feb 22, 2001 | 11:40 AM
tranny doctor's Avatar
Hello. My name is F.C. It only does it while racing at full throttle while in the D position. What is working together in 2nd and 3rd gears are the forward clutches and the input sprag. We know it not the forward clutches because they are working together on all other gears except reverse, so its has to be in your input sprag. When checking a input sprag on the bench you can put it in a vise and see if its going to hold and most of the time it will hold but put that same sprag into a car and now you are moving weight, the sprag will not hold. Its either your sprag or your sprag race. If you do change out your sprag, go with the larger late sprag or even better go with a mechanical sprag. F.C.
Old Feb 22, 2001 | 05:15 PM
Z28IROC350's Avatar
Ok, now that I'm getting screwed out of $4K on my taxes, it's gonna take some time to get this fixed. I also need $2K in body work thanx to my G/F. Thanks for the input !
Old Feb 23, 2001 | 03:51 PM
Danny P 86Z28's Avatar
More than likely the problem is the 3-4 clutches are slipping. GM did not put enough cluch plates in the 3-4 clutch pack and this is a weak point. A good rebuilder will add additional clutches in the 3-4 pack to make it stronger.
Brendan
Feb 20, 2003 02:14 PM
mystikkal_69
Car Audio
Dec 8, 2001 07:20 PM
FIRECHICKEN
Dec 4, 2001 08:56 PM
ADMZ24
Aftermarket Product Review
Apr 26, 2001 02:40 PM
kidpunkr
Jul 28, 2000 07:52 AM
