Open 10 bolt V6
Car: 86 Z28
Axle/Gears: TBD
Open 10 bolt V6
did the open 10's come with the GM 7.5 or the 8.5? what spline axle. Reason: i'm thinken of getting new axles+c clip eliminator, + limited slip and maybe disk brakes. any info would help.
Faster than a bullet, these are F-body's don't even pull it.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
All third gens came with 7.5. Around the late 80's it was upgraded to 7.625 (7 5/8). Also around that time the axles were upgraded from 26 to 28 spline.
If your 83 diff is still original then you have a 7.5 with 26 spline. You can install the 7 5/8" gears on that carrier. You can upgrade to 28 spline by using a SLP Torsen limited slip and axles from www.drivetraindirect.com part number KAC7-A7. If you go to disk brakes you don't need c-clip eliminators. NHRA rules state that you need an axle retention device. Disk brakes do the same thing.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
Car: Trans Am
Engine: L69
I have a 3.08 rear end I htink it has a 7.625 carrier, I wanted to use the carrier on my 3.73 reared but the 3.73 gear was too small for it.. Does this mean the 3.08 rear has 28 spline axles? Thanks kevin
Car: 82 camaro SC
3.08's are on a series 2 carrier. 3.73's require a series 3 carrier. 7.625 is the ring gear size, not the carrier. The carrier is the same with 7.625's as 7.5's. The spline change took GM a while to do, so the only way to tell for sure is to count.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
pre 28 spline axle rears are 7.5??
hmm
I bought, and installed a powertrax locker for a 7 5/8 rear with 26 spline axles.
It would seem to me since they sell the above product and I installed it and dont have any problems that the rear is a 7.625
but i dont know enough about rears to tell you for certain.. just my experience
hmm
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
BurlyChev
Aug 22, 2015 01:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
