will this blow up?
Old Feb 17, 2001 | 06:03 PM
buddman91rs's Avatar
will this blow up?
i have a 700-R4 that is 9 years old and has seen moderate street use the whole 9 years(with the exception of racing 30 miles at WOT for about 5-10 min., it was when my grandad died ) will it be able to handle a 500hp 383? will i have to rebuild it or put in a different servo or what? please help
1991 RS LO3
mods: 14" chrome air cleaner, straight-piped after cat exhaust with one chrome dual tip on the left side.
future mods: headers, removing smog equipment, and as many cheap mods as i can find
aol s/n: budman8503
Old Feb 18, 2001 | 01:41 AM
EO273KiD's Avatar
Humm, well all I can tell you is, I just got done rebuilding my tranny... and I never knew what I was missing until I drove it around for the first time today...
do the rebuild yourself, and have fun burning your tires away...
Owner of a 1989 IROC-Z Camaro, a.k.a. "The Babe Magnet". Painted a cheap metallic blue that chips off all too easily and covers over the IROC-Z decals on the doors, also has non-leaking T-tops, ps, pw, power rear hatch, working A/C. Mods: SLP intake runners, gutted MAF sensor, adjustable fuel pressure regulator, modified air spoil, 3.27 posi rear end.
Broken stuff: rear spoiler brake light, driver side lock, power antenna, tilt steering, rear end bushings, cracked passanger side ground effect, washer fluid tab, leaking exhaust and a rotted through muffler that sparks when the car bottoms out while driving like any 17 year old does.
Old Feb 18, 2001 | 08:55 AM
how hard is it to rebuild my tranny? how long will it take and do i need any special tools?
1991 RS LO3
aol s/n: budman8503
SUCKING GAS AND HAULING *** -The American Dream
Old Feb 21, 2001 | 10:48 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
Tranny rebuilding is not hard as long as u have a manual or something to guide u along the way! The type of rebuild im refering too is just changing your cluth packs,band & maybe installing a shift kit while u have the thing all opened up.
#1 U HAVE TO HAVE A 700R4 MANUAL
#2 U HAVE TO HAVE CONFIDENCE IN YOUR OWN SELF!
#3 IF U DO THE WORK THAT I MENTIONED UP TOP IT SHOULD COST U NO MORE THAN $150-200 COMPLETE WITH THE SHIFT KIT INCLUDED!
just my $ .02 ya know?
Tra/maro
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Mods: 3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255l walpro f/pump
Old Feb 21, 2001 | 11:37 PM
GTARob's Avatar
I have a T-5 going infront of a similar motor.(see sig ) My t-5 is on a difinitive suicide mission. I have seen some of the 11 and 12 second stang boys at the track still running thier T-5's though.
1989 GTA TRANS AM
Was a TPI 305 & t-5 car.
Is now 383 stroker w/ the same T-5
World products Sportsman II heads. Lunati pistons and custom ground camshaft. Will dyno after the break in but is estimated at 450 hp and 520 ftlbs. The T-5 is on a suicide mission.
Old Feb 22, 2001 | 05:00 PM
82z's Avatar
82z
In order to rebuild your tranny you will need a manual, parts cleaner, compressed air, and a birdcage/return spring compressor. It will take ~20 hours start to finish to do a really through rebuild- disassembly, parts cleaning, inspection, and reassembly. The key is to not fake yourself out with the tranny's perceived complexity. Remember it is only a transmission. The best part is when you are done. You get to say, I built that, that's why it works so well. You also save ~1000$ as opposed to a comparable high performance rebuilt tranny. Plus doing it yourself is the only way to make sure it gets done right.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Feb 22, 2001 | 07:49 PM
mikeage2's Avatar
hey!what about all the special tools you need to change all the seals and bushings?
id say that is the worst part about the whole damn thing is changing seals.on my first 700 rebuild,it only lasted like 400 miles cuz i was to lazy to change the 1-2 piston seal.i wont do that again lol
yes you do need a good information source(manual)and you do need to have a pretty good brain for mechanical stuff.wherever you decide to rebuild,keep everything clean and orginized,and in a place where nobody will screw with it(fo rme it was a room in my basment)
86 camaro:was a v6 car with stick,converting to v-8..NEED A V-8 T-5!!!!!!!!!!email me if you have one!!!
350 cylinders bored .040 over.a little oves 9:1 compression(getting a blower some day when im rich lol)line bored.deck milled a little(was pitted)
trw forged pistons with summit stage 2 polished rods with arp bolts.
194 intake valves,pocket ported,gasket matched,and polished ports,old vette intake with new zinc 650 holley
ase certified for a few years,learned alot though
working on freakin NEONS ,cirruses,tauruses,cobras(wel at least they look nice lol)and intrepids all day makes me drink too much
good job security though
Old Feb 22, 2001 | 10:03 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
I had a hell of a time using those full o-ring seals on the input shaft and keeping them in place while putting the pump on. The split seals are a dream... I don't care what people say.. I saw more full seals pinched or cut that leak like a seive on startup. Split seals stay put.
Old Feb 26, 2001 | 02:10 PM
yeah im very mechanically inclined, even at 15, im going to work at a garage this summer so i can get some of the stuff for cheap and have some professional help if i need it. thanks guys
1991 RS LO3
aol s/n: budman8503
blackz281le
Jan 11, 2016 07:51 AM
Fanatic1074
Oct 2, 2015 03:47 PM
86IROC112
Sep 28, 2015 08:17 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
90formulaVortec
Sep 3, 2015 09:26 AM
