starter/flexplate problem.
Old Nov 4, 2008 | 06:52 PM
Jammin'Trey's Avatar
Ok so i have a 168t flex plate with no counterweight on it, my stock 305 has a 153 t with a counter weight on it. I put a 355 into my 89 RS camaro and had to bu a diffrent starter for the bigger flexplate. But the starter doesnt throw out the gear far eneough to hit the flex plate teeth completly, it hits maybe 1/4 of the tooth on flexplate.
I have rounded off a couple teeth on the flexplate and my car is not driveable what should I do?
I beleive this motor is internally balanced but im not sure what should i look for? On my 305 the flexplate bolted to a perfectly round crank, on this 355 it has a hump on the end. I assume this is a built in counter weight?
If it matters i have a 2 piece rear main seal. and 3 holes for the starter to mount.
Old Nov 4, 2008 | 06:56 PM
Guest
Guest
Posts: n/a
Re: starter/flexplate problem.
did the starter come with shims?? now it sounds like u need a new flywheel
Old Nov 4, 2008 | 07:04 PM
yea, starter came with shims but thats not what im talking about. I think I need a 153 tooth FLEXPLATE internally balanced (because I have a 2 piece rear main sea??)
Old Nov 4, 2008 | 07:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It would have been cheaper to get the 153 tooth flexplate.
That's usually a shimming problem.
Replace the flexplate and check your starter clearance.
It's not a built-in counterweight, it's just how the crank is.
Buy a flexplate of either diameter for any stock 2 piece RMS engine except a 400, and use it with the appropriate correctly-shimmed starter.
Old Nov 4, 2008 | 09:09 PM
So internally or externally balanced???? does the flexplate i need have a counterbalance weight on it or not?
Old Nov 4, 2008 | 09:33 PM
Im starting to think the flexplate may be on backwards, would this cause my starter to only hit 1/4 of the flexplate teeth. I just need it to reach out a little more when it enguages. This is really erking me to no end. This motor swap has been a bitch.
Old Nov 5, 2008 | 06:52 AM
anyone? apeiron?
Old Nov 5, 2008 | 04:12 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Forget about balance. The word you want to care about is "stock".
If the flexplate was on backwards, the torque converter wouldn't bolt to it.
Old Nov 5, 2008 | 07:23 PM
its not a stock motor!!!!! whatever. the motors not from a camaro. AHHHH!
Old Nov 5, 2008 | 07:39 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It doesn't make a lick of difference if its a stock motor or not. Pick a random application that could have come with a 2 piece RMS small block, and get a stock flexplate for it. You've already got both starters, so there's no way you can get it wrong.
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
HoosierinWA
Oct 7, 2015 10:15 AM
mcbitchman
Sep 29, 2015 12:32 AM
383cam
Sep 9, 2015 06:01 AM
