Shifter cable..700r4
Old Mar 1, 2001 | 12:00 AM
TELLEZ's Avatar
This just happened today, in front of the parts store I could not get my car into park from Drive; the shifter felt loose, it would just move back and forth. When I got under the car and pushed the shifter lever on the tranny into park I got back in the car and tried to put it in drive and this time it did shift down into reverse, then to neutral then drive and so forth, but the problem comes when I try to put the tranny into park from D, N, or R. it wont go back up. Whats up? Will replacing the shifter cable fix it? I bought the cable but now I am not sure if that is the whole problem, thanks guys.
88 IROC-Z,L98 350 TPI, 700R-4 Tranny 2.77, K&N Filters, 126K Miles runs great.
Old Mar 1, 2001 | 01:48 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It sounds like the bolt through the pin in the end of the cable into the shift lever has come loose and is allowing the pin to slide in the slot. Put the selector and the manual shaft of the transmission into neutral and tighten it down.
Old Mar 1, 2001 | 12:55 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I had a similar problem a couple years ago. My problem was the shifter cable was binding when I tried to put it in park. I replaced the cable and that fixed it.
'91 GTA with TPI 350 & T-Tops. Just a few mods, if you want to find out just line up next to me at a stoplight!
Added bonus:
Wife's car is a '00 Grand Prix GTP!
mcfastestZ28
Oct 5, 2015 07:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
