Installation on a new rear-end?
Old Feb 28, 2001 | 09:59 PM
StCr19's Avatar
Car: 1991 Galant VR4
Engine: 2.0L 4G63 Turbo
Transmission: 5sp transaxle/transfer case
Can anyone give me an idea on how much this would cost? I want to replace my limited slip drum brake rear with a posi disc brake rear.
Old Mar 1, 2001 | 01:35 AM
Gerald Jackson's Avatar
StCr19, you could possibly make the change in one weekend. The hardest part will be the e-brake cables. There are 3 bolts (2 going to the trailing arms and 1 that goes to the cross bar) that really hold the rearend to the frame. Then there are the 2 shock bolts and the drive shaft bolts (4).
82 cross-fire, 410 gears
700r4
Old Mar 1, 2001 | 09:34 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The axle swap itself is easy; the brake change sometimes isn't. The calipers might need a rebuild. If you have the parts from the years that require the master cylinder to be changed, expect a big headache while trying to bleed the new master cylinder.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 1, 2001 | 06:01 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I got you covered. Rear install
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
[This message has been edited by GMTech (edited March 01, 2001).]
Old Mar 1, 2001 | 06:07 PM
StCr19's Avatar
Thanks a lot.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
