Best direct T5 replacement
Old Nov 7, 2008 | 04:30 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Well my T5 finally went south and I'm considering my options. I don't want to revive the ol' T5 vs T56 debate (though somewhat relavant) Rather, what will directly replace/repair my tranny and be stronger. I'm running a warmed over L98 with an occaisional (up to) 200hp on the juice. I saw a while back a replacement gear set for the T5 which is a lot tougher but haven't been able to find it. Also, I think there are aftermarket units which will bolt in. Any suggestions? Thanks.
Old Nov 7, 2008 | 07:54 PM
85TransAm406's Avatar
Car: 1985 Trans Am
Re: Best direct T5 replacement
www.gforcetransmissions.com
Their street 5 speed is the rebuild/upgrade t5.
Old Nov 9, 2008 | 11:38 AM
Car: 89 IROC
Engine: 6.8 HSR N2O
That's the one! Thanks.
Old Feb 21, 2009 | 06:35 PM
Dennis-Z28's Avatar
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
Rather than start a thread I'll jump onto this one.
I was deciding wether or not to build a 383 but I have the T-5 and know it is rated to 300lb-ft. If (or maybe I should say when)the tranny fails what actually fails? Is the housing going to crack or is it all internal gear failures? Just want to know if I need to replace the T-5 from the start or if I could wait until it blows and then have it re-built stronger afterwards.
Old Feb 21, 2009 | 07:07 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Usually the tko or t56 is what people use to upgrade their t5. How much is the gforce t5? It doesn't list a price.
Dennis, the nice thing about replacing the tranny now is that you can get a few hundred $ for your T5 setup to help offset the cost of the upgrade.
Old Feb 23, 2009 | 08:45 AM
Car: 89 IROC
Engine: 6.8 HSR N2O
When mine went it was the teeth on the imput shaft where it meshes with the counter cluster. Stripped all off during a normal shift to 3rd. Must have had some stress fractures.
Good point above regarding selling your T5 while it's still good.
I went with a TKO 600. Great tranny and worth the $3k if you can handle that. Only minor mods required to make it fit (that is if you're fabrication skills are good) Had to make spacers for the x-member, special shifter handle and a slight mod to the torque arm.
Old Feb 23, 2009 | 09:27 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I'm going the TKO 600 route too... Heard too many bad things about GForce and their rebuilt T5's...
Raf
wigmobile
Feb 26, 2025 02:56 PM
djmarch
May 8, 2016 11:32 AM
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
Lmancha96
Sep 25, 2015 08:11 PM
gta892000
Sep 16, 2015 12:37 AM
