Differential Gasket
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Differential Gasket
stock rear in a 88 camaro, 2.73 gears where can i get the gasket ? i know i can just use RTV but i want to make it easy for the next time. I checked the local parts stores and they do not carry it. Anyone order one online ? Any help would be appreciated, I got my royal purple already
Car: 88 Camaro
Engine: 305 TBI
Re: Differential Gasket
i ended up getting
Rear End GasketMost 1964-90 GM 10-Bolt 8.5''
Part Number # 720-84B
$7.99 $7.99
from jegs, i went out and and counted the bolts, and this gasket looked right. Any thoughts ?
$7.99 $7.99
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I haven't used a gasket for a diff in about 25 years. If you're worried about removing the old silicone the next time you take the cover off, just how often are you removing it? Even if you don't change your diff oil in less than 4 years, it's not that bad to scrape off old silicone.
