How do you switch "carriers"??
Old Mar 2, 2001 | 11:15 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Ok, I have a 9 bolt rear with 2.77 gears! The only thing I can put in this thing is 3.08 gears!! How would I swap to a 3 series, 9 bolt carrier if I could find one so that I can put 3.45s or 3.70s in there!???
1986 Trans AM
305 TPI
200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.77's....oh joy) :P
Completely Stock
Soon to upgrade to a 355 converted from TPI to Carb, Edelbrock 750CFM Carb, Edelbrock Performer RPM Intake, Hedman Shorty Headers, Stock casting pocket ported heads (2.02/1.60 - 65cc), XE268 Cam, Moroso HEI ignition kit with external MSD Blaster II Coil and an MSD 6-AL Box!!
Current project: Keeping my 305 running until I get my income tax returns!
Old Mar 3, 2001 | 07:38 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I don't have much experience with the 9-bolt, so I don't know if they used "2" series and "3" series carriers like the 10-bolt did. Anyway, to switch carriers, you just remove the old one, and put the new one in. I would say swap out the ring gear, but your old "2" series wouldn't fit on the "3" series carrier, so you would have to get a new ring gear. If you want to see about setting up a carrier and ring gear, check this out (I know it says 10-bolt, but its essentially the same) 10-bolt
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Veaceonee
Sep 29, 2016 08:15 PM
RacerM
Sep 28, 2015 04:25 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
