SLP shift recalibration kit...anyone have it?...opinions?
Old Mar 3, 2001 | 11:06 AM
BlackBird305's Avatar
I was just looking at SLP's website and the shift kit for the 700-r4 is on an "internet special" for $85...i was thinking about getting it...anyone have it?...experiences?...good bad otherwise?...how hard are the shifts?
thanks a lot guys
91 Pontiac Firebird...305 TBI
black, t-tops, auto
K&N 14x3 open element air cleaner, 3 inch high flow cat, 3 cat-back into a flowmaster 40 series, kenwood head unit, pioneer 5 1/2's, Infinity Kappa 6x9's, 2 JBL 10's...more mods soon!
Old Mar 3, 2001 | 10:10 PM
sorry just trying to get this to the top
Old Mar 3, 2001 | 11:58 PM
Dirk's Avatar
TGO Founder/Former Owner
Car: 1992 GTA
I have it and I love it! I also have the Darrel Young Monster valve (the "big" one) and it's a bit bigger than the one that came w/ the SLP kit. I don't know how much that affects things Shifts are lightning fast with the shift kit. Not neck snapping harsh, just fast! It's great. Absolutely no problems with it at all.
This is also the only shift kit I have ever had. So I can't compare it to the others. But I have had people in my car and they like it I have ridden in Willie's car and I am not sure what shift kit he has, but his definately snaps your neck even at low RPMs.
Hope that helps you some
Old Mar 4, 2001 | 10:58 AM
thanks a lot dirk...anyone have any comparisons of the SLP compared to the Trans-Go or B&M...thanks
Old Mar 4, 2001 | 04:30 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Well, i have the B&M kit. It shifts hard. I've had it about 5 years now, and my only complaint is in wet weather. It had a tendancy to break the tires loose just at part throttle. I've been in Dirk's car and my B&M is alot harsher then his SLP, but he has a higher stall TC which softens the shifts, so a bit difficult to compare.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
[This message has been edited by Justins86bird (edited March 04, 2001).]
Old Mar 4, 2001 | 05:06 PM
86SCBNJ's Avatar
I have the SLP shift kit. It chirps em at full throttle. At part throttle nice and firm. A excelent shift kit for the money (under $100).
86 SC, 305 LG4, TH700R4, SLP headers, 3" cat and exhaust. Mild cam 204/214, .423/.442. SLP shift kit, richmond 3.73's w/limited slip. Susension Technique Sway Bars, Globel West Wonderbar, Poly everything bushings, Metco LCA's, Lakewood Panhad Rod. 16" ROH, with Toyo 245's. For autocross, 16" IROC's w/bfg R1's... Need more speed.....
Old Mar 4, 2001 | 06:38 PM
Black82Z's Avatar
I have the B&M shift kit, it shifts hard all the time, even at light throttle it snaps your neck back a little.cost me 120$ canadian took about 3 hours to install. was worth it i think
Old Mar 4, 2001 | 07:36 PM
98_1LE's Avatar
Do either of these kits allow you to change the shift points? Say up from 4600 to 5200?
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Old Mar 4, 2001 | 09:52 PM
<font face="Verdana, Arial" size="2">Originally posted by 98_1LE:
</font>
Nope
-Justin-
Old Mar 5, 2001 | 08:56 PM
dirk did you do the install?...if so how much time did it take you?...thanks
Old Mar 6, 2001 | 12:47 AM
chrisfrerick's Avatar
i bought one but never installed it. i decided to go with a transgo full race rebuilt kit when my trasmission broke. if you want it you can have it for $50 plus shipping everthing is still packaged with instructions and vet servo.
Old Mar 6, 2001 | 03:12 AM
Dirk's Avatar
Car: 1992 GTA
I pulled my tranny out because I put in a new torque converter so I had all the clearance I wanted.
All in all I'd say maybe 2 or 3 hours to do everything. I had fun taking off the snap rings on the servo cover and the boost valve. It's not a hard job, you just have to have patience becuase everything is slick w/ tranny fluid.
Well worth the time and money!
Old Mar 6, 2001 | 12:39 PM
KevinP92Z's Avatar
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
I've had SLP's shift kit in my car for about 4 years. No problems. Firm, but not too firm. Their instructions are very detailed (about 15-18 pages) vs some other shift kit instructions . As long as you can get the car up high enough to allow crawling room, the install goes pretty easy. 3-4 hours avaerage, some more, some less.
I had a TCI kit in my other 700 in my blazer, and 1-2 is a little too harsh for the 4x4 drivetrain, but 2-3 & 3-4 are too soft. This is with vette sefvo kit etc.
Bottom line is I agree with those liking the SLP kit.
KevinP92Z
92 Z28 383 SLP cam,SLP headers,SLP 2ontheLeft,Trick Flow TW heads & pistons,Edelbrock base,Accel SuperRam,52mmTB,Scat Crank & forged ConnRods,MSD 6AL,SLP convertor,Baer 13/12" Track,Moser axles,Hotchkis,Genuine GM 3.42s,SLP HD Torsen,17x9" chrome SS rims
96T/A w/SLP Ram Air,SLP 2ontheLeft, Bilsteins, Baer, Hotchkis, Genuine GM, Torsen
76 4X4 Blazer 400TPI project
Old Mar 6, 2001 | 03:37 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Do you have to install the servo when you do the SLP shift kit (does it even come w/ it, or are you guys adding your own.) I want to put a shift kit in, but sure as hell don't feel like dropping the tranny to get to the servo (and i'm not using the BFH on my verts floor.) So if the SLP is OK w/o the servo then i'll buy yours chris.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
racereese
Oct 3, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
