governer install
Old Nov 16, 2008 | 07:15 PM
Jammin'Trey's Avatar
governer install
Hey guys, I swapped a .030 350 into my camaro, 350RWHP....
Anyway, I am looking to install a B&M governer recalibration kit in my 700r4. How does it go in? I have installed 2 shift kits and a corvette servo in my day but have no clue about a governer recalibration kit? From what I can tell it looks like I have to take off the tailshaft??
Old Nov 16, 2008 | 07:22 PM
AlabamaGuy's Avatar
Car: 1991 Camaro RS
Engine: 454
Axle/Gears: 2.73 open
Re: governer install
Should just remove the clip holding the governor cover in place then remove the governor cover, then pull the assembly out.
Old Nov 16, 2008 | 09:43 PM
ok, wow, is the governer cover the big round pice on the drivers side??
Old Nov 17, 2008 | 09:05 PM
AlabamaGuy's Avatar
Car: 1991 Camaro RS
Engine: 454
I believe so.
Old Nov 19, 2008 | 07:50 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
Yes, and it's easier to work w/ than the servo. Have a pan to catch the fluid that is likely to come out. It won't be much if you don't have to lower the tail of the trans to get the governor out. But if you do, you can lose up to a quart or so of trans fluid.
Also, if you end up lowering the trans tail, be sure to remove your dist cap or at least have someone watching to make sure you dont end up cracking it.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
