cracked flex plate
Old Nov 19, 2008 | 03:17 AM
carfreakpeewee's Avatar
Car: 91 RS
Engine: 305 tbi
cracked flex plate
Does anyone know what causes the flexplates in these cars to crack. I replaced the one in my car three months ago and it has already cracked. I want to figure out if there is something else wrong or if I just got a defective part before I break down and pay someone to fix it this time since I don't have a garage and don't want to do it in the dead of the winter in the pacific northwest. Thanks.
Old Nov 19, 2008 | 11:30 AM
dyed's Avatar
Car: 84 Z/28
Transmission: 700R4 - rebuilt by me
Axle/Gears: 3.73 posi
Re: cracked flex plate
Too much HORSEPOWER!
Not likely though with a 305... Other than that, you have alignment issues. Make sure the tranny is pulled up tight and that the t/c fits nicely into the pilot. Of course, it could just be a bad part....
Also, I've seen it done without actually pulling either the trans or engine, but you gotta have some long wrenches and little hands.
Old Nov 22, 2008 | 03:12 PM
turbo11g's Avatar
You need to go to the hardware store and get some long bolts, like 6 inches, and put those in the bottom two bellhousing holes. Remove the other 4 bolts, torque converter bolt and remove the crossmember. Put a good jack under the tranny and slide it back until it won't go no more. That should give you plenty of room to change the flexplate. Done this many times.
Old Nov 22, 2008 | 08:11 PM
lucky14's Avatar
Car: 91 Z28
Engine: 383 TPI
Transmission: 700R4 B&M Hammer Shifter
Axle/Gears: Stock Posi
I just cracked mine.. I built an all new 383 stroker.. upgraded EVEYTHING... that is until my wife was lowering th engine and I was guiding her on the engine mounts and realized hey dummy you reused the beat up oldflex plate...
Well the flext plate made it through the engine break in... then first WOT after 250 miles... cracked...
I am having Santa bring me a BM or TCI upgraded unit.. check out summit.. they really are not that bad about $90.00.
Old Nov 23, 2008 | 03:35 AM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
yep it does work you don't have to pull the engine out. i pulled my tranny and put one in. over 2 days of work 3 hrs one day to take it out. which i was slowly doing it since i never done a tranny pull on a camaro which btw very easy. and putting it on was good. all u need to know is make sure when u pull out the tranny if not using bolts to hold the engine is take the dist cap off b/c it will break on the fire wall.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
tyeo098
Nov 30, 2015 06:27 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
codeysabatini
Nov 10, 2015 04:07 PM
