700R4 problem
Old Mar 14, 2001 | 07:59 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
700R4 problem
when it shifts from 2nd in to 3rd it will flare up about 500rpm's before it goes into 3rd.it has a 144,000 on it
1991 banditt2 #130 of 600
Project 350 Banditt
<A HREF="http://clubs.yahoo.com/clubs/streetdawgracing" TARGET=_blank>
http://clubs.yahoo.com/clubs/streetdawgracing</A>
http://y42.photos.yahoo.com/tonysams72.
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation
Old Mar 15, 2001 | 04:16 PM
Pro Built Automatics's Avatar
Time for a rebuild.The 3-4 clutch pack is the biggest weak point in the 700R4 transmission. You went 144k miles without a rebuild?, that is pretty good. When rebuilding this unit you should install the latest Borg Warner Hi-Energy 8-pack with Kolene steels if you are going to rebuild it yopurself?. There a lot of other things you can do to this transmission to get better quality performance shifts, and longer life. I carry everything needed to do this yourself. If you are not going to do the transmission yourself, I offer complete performance transmissions & torque converters with a one year warranty. Depending on what type of driving you do will determine what transmission & torque converter are required. I will need to know the engine modifications (if any), what rear end gear ratio you have? etc. This transmission would be custom built for your particular application. If you have any questions call me at 800 7763288 Mon-Sat 10-6 PST.
Glad Too Help!!!
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
