Update on blown slave cylinders
I just finished installing the entire new hydraulic system. Just what I wanted to do. Yeah right......
The clutch pedal is rock solid. This with a factory bled system. So yesterday, the new slave cylinder I put in, and the bleeding process was correct. I have finally figured out what is happening........
The clutch slave cylinder piston is already at its maximum travel. This is due to the pressure plate being collapsed, or something. It is not springing back to normal position. So the clutch fork is extended away from the slave cylinder rod. Trying to push the clutch pedal, just pushes the piston right out the slave cylinder body and it blows up.
So, this means I have to do my tranny swap all over again! :-(
Remove everything down to the flywheel. This totally sucks............
218 miles on that clutch and the pressure plate fails. Everything worked flawless, and then nothing. Wow.......
I run into this at my job with parts and assemblies that cost in the thousands. It can happen to any part. I just don't like it when it happens to "my" stuff.........
FORMULA 350 TK
Southern California 3rd Generation F-Body OrganizationŠ
FORMULA 350 TK
You didn't notice this until after you swapped hydraulics? Personally I would of noticed it right off the bat not having brake fluid on my hands....
Intresting though....sorry man...I know what a PITA dropping the 5-speed is (not really hard, just not too enjoyable, especially if you accidently drop it on your head)
1984 WS6 Hardtop Trans Am
Former L69 Car under restoration
1984 T-top Trans Am
4-bolt main 350, performer intake, headers, Holley 650, T-5, hayes clutch, dual elec. fans and 3.23's.
Daily driver and restoration
13.98 @ 101
1984 T-top Trans Am
13.98 @ 101
The ball stud is fine. The clutch fork is fine. The pressure plate fingers have failed in a "down" or applied position. The slave cylinder piston has no resitance and nowhere to go, but blow apart if the clutch pedal is depressed. Did I say "depressed"?
Sorry to hear it ended up being mechanical. Keep us up on what you find. I'll be very curious to hear what actually failed and why.
1984 Z28 350
Never argue with an idiot, they'll just bring you down to their level and beat you with experience
My Web Page
1984 Z28 350
My Web Page
I'd be very interested in how the protologists solves the problem I'd give them with whatever failed...
1984 T-top Trans Am
13.98 @ 101
1984 T-top Trans Am
13.98 @ 101
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
