T/O Bearing worth keeping
Old Mar 15, 2001 | 07:29 PM
BigChevy342's Avatar
How can you tell if your throw-out bearing is good? If it spins? Can the throw out bearing cause the whining noise that my tranny makes or is it the fly wheel? It starts making the noise at about 2 grand, and it clatters/i've got the transmission pulled right now and the clutch is shot and the fingers on the pressure plate are worn and bent. also what type of grease should i use for the throw out bearing
it's on a 5 speed p/u
86 Stock Iroc, 305 tpi
91 Chevy p/u/350/5speed/3.73/ram-air
Old Mar 15, 2001 | 07:32 PM
Whoops sorry about that, if you didnt catch that other message I forgot to add this in as well, When i hold the clutch in you can barley hear the clattering but when its out in neutral it is very loud.
thanks a lot
Old Mar 15, 2001 | 08:58 PM
Gerald Jackson's Avatar
bigchev342, I always use the rule (i forgot who told me) that when you replace the clutch always replace the t/o bearing.
82 cross-fire, 410 gears
700r4
Old Mar 15, 2001 | 09:08 PM
Yea I was going to change it anyways, but i was going to replace it anyways but i was curious if the throw out bearing is what was making all the whining or if thats just responsible for the clattering.
thanks-
Old Mar 17, 2001 | 12:14 AM
i figured out the problem if you guys were curious, it was the pilot bearing, i pulled it out and it was hollowed out because it was never changed,
J-money
Jan 4, 2019 09:45 AM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
lakeffect2
Sep 7, 2015 03:52 PM
rudolphschenker
Sep 4, 2015 02:41 AM
90formulaVortec
Sep 3, 2015 09:26 AM
