popping noise during a shift?/
Old Nov 24, 2008 | 10:19 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Ok i checked all my mounts etc and theyre good but when i shift, something from my trans back is popping/clunking whatever you want to callit, almost like my ring and pinion have too much backlash and its jumping too much
any ideas?
Old Nov 24, 2008 | 11:51 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: popping noise during a shift?/
The most likely problem, to check first, is the mount at the rear of the trans. Try jacking up the rear of the trans, it should stay snug against the crossmember. If not, it's time for a mount from Energy Suspension, because theirs has an internal interlock hidden inside the polyurethane.
Old Nov 24, 2008 | 11:38 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
wait you mean the torque arm bushing?
Old Nov 25, 2008 | 12:42 AM
a1990camarors's Avatar
Car: 1990 rs 1992 z28 1995 jeep
Engine: no engine, 383stroker, inline 6 4.0
Transmission: none, t5, auto
tranny mount 95% sure. had one do the same things too me. really simple to replace any manual for you care will walk you right threw it.
Old Nov 25, 2008 | 11:20 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The torque arm bushing, while also rubber, and very near the trans mount, seldom fails.
Old Nov 25, 2008 | 12:02 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
the rear tran mount is good, replaced it a few months ago when it snapped on me, that mount it pretty distinctive when it goes because the shifter has a tendency to walk out of your hand
turns out its just slop in the diff, gotta another one im building right now so im just waiting it out
thanks for your help
Old Nov 30, 2008 | 05:51 PM
onesmartidiot's Avatar
Car: 85 marrow z28, 88 thunderbird 5.0
Engine: 305 4bbl, 302 cobra efi
Transmission: 700r4, aod
Axle/Gears: the crappy one
did it do it every shift?
reason i ask, is mine does a popping/ small grinding noise during shifts when im really getting on it.
what do you mean "slop in the diff"?
just curious
-blain
Old Nov 30, 2008 | 11:07 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
well yeah, it does it every shift, when i get on it i dont notice it because my exhaust is too loud but when im just driving normally it does it.
slop in the diff being the backlash is set off becuase its a 19 year old car thats been abused and when i put it on the lift, i had my friend hold the tires in place while i tried to move the driveshaft by hand, its got a bit of slop, so when the drivetrain is in neutral the ring and pinion have excessive amount of space between the teeth, when i put power into the drivetrain it takes a bit more to travel and when the teeth contact it makes the thud noise
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
Racerx974
Sep 19, 2015 10:16 AM
89fast5oh
Sep 8, 2015 09:55 AM
