9 Bolt Disc. Fluid Change
Old Mar 20, 2001 | 09:09 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
I am going to change the fluid in my 9 bolt rear because, i looked over my car's repair history (and yes, i have every receipt and bill since the car 1st rolled off the lot), and there's no indication of fluid change... I have about 19x,xxx on the car. Do i just take the bolts off the rearend cover, drain fluid and then retighten them? What kind of oil (i know i should use the additive from GM). Anything i should look for and pay attention to when doing this? Any help is appreciated. (BTW, i did do a search but MS Internet Exp. kept trying to crash on me)
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
Old Mar 20, 2001 | 09:19 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I would use the gm syn rear end fluid and there addtive, that is all I use in mine. Unbolt drain it out and then fill it back up, it is simple to do.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Mar 20, 2001 | 09:27 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
You answered all my questions right there I always worry with things like the rear end that i won't tighten something correctly and it'll become f--ked up. (Althought i wouldn't mind a 10 bolt with some better gears) Thanks.
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
-Gutted cat
-!AIR
Old Mar 21, 2001 | 01:18 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I would install a new gasket while you have it apart also.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES,it is a 9 bolt & YES they are 3.73's, not 3.70. 4.11's to follow soon )
www.koolmeister.com
Terrell351
Jun 13, 2021 01:13 PM
maroe624
Apr 16, 2017 08:29 AM
Thornburg
Aug 25, 2015 01:46 AM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
