Flex plate to torque converter match up
Old Mar 21, 2001 | 09:03 AM
Wicked82Firebird's Avatar
i'm replacing my 2.8 engine in my 84 Bird...question is....since i'm getting a new flex plate with the engine..due to this model being externally balanced..is there a special need to align the flex plate and torque converter? or can it just simply be bolted on without a difference?
1984 Bright Red Pontiac Firebird...2.8L V6..173CI...2BBL Carb..15 inch wheels..o.o
Old Mar 21, 2001 | 09:59 AM
Superblue87Formula's Avatar
you are getting a new trans too right? A 6-cyl trans won't bolt to an 8-cyl engine...
As long as the rotating assy of the engine is balanced, you can bolt the converter up any way you want.
Old Mar 21, 2001 | 08:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The flex plate and balancer for an externally balanced engine are all thats required to compensate for the internal out of balance mass. The torque converter is neutrally balanced and doesn't care about the position it it bolted onto the flex plate.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
mhatfield 14
Oct 24, 2015 07:48 AM
xxx3man`
Sep 23, 2015 10:37 PM
gwade12
Aug 8, 2015 08:17 AM
