speedo gear for a 3.73?
Car: 86 Grand National / 90 Formula
Engine: 3.8 V6 / Procharged 5.7tpi
Transmission: 700R4 / 700r4
Axle/Gears: 3.42's / 3.23's
how many teeth are on the speedo gear for a 3.73 gear (700r4 92 camaro g92 axle)
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: speedo gear for a 3.73?
First, 3.73:1 wasn't offered in '92. But if you have a '92 car and a '92 700R-4 and 3.73:1 gears, then you need thelight blue-ish/gray-ish 15 tooth drive gear, part number 8642620, and the dark gray 44 tooth driven gear, part number 25513051, if you're running 245/50R16 tires.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
