transgo tv install help
Old Dec 3, 2008 | 07:58 PM
ak1059's Avatar
Car: 83 z28
Engine: 350 ZZZ
I am in the middle of installing a transgo tv valve and new spring. I removed the plunger and spring but i can't seem to get the old tv out. I can't see it or feel it in the valve body. Any help would be awsome this is my first time doing this and I am sure I'm just missing something simple here.
Abraham
Old Dec 4, 2008 | 05:34 AM
ak1059's Avatar
Car: 83 z28
Engine: 350 ZZZ
Re: transgo tv install help
anyone have any ideas. need to get the car back together
Old Dec 4, 2008 | 03:30 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
TV is :
roll pin removal
remove the aluminum sleeve
the plunger is removed with or after the sleeve
spring is behind plunger
tv valve is next with flat end toward spring
bottom sleeve (if applicable)
Most kits add a small conical assist spring behind the TV valve. Also the large spring is replaced typically.
Im not exactly sure what youre kit came with. But all parts should come out fairly easily as long as you are removing them right. A magent helps sometimes with the spool valve removal. Also you can reinstall the spring and plunger, pop it a few times and free stuck parts.
Call Dana at ProBuilt.
Old Dec 4, 2008 | 06:03 PM
ak1059's Avatar
Car: 83 z28
Engine: 350 ZZZ
thanks, i am just installing the transgo jr kit. i have the valve body out but the roll pin won't come out now.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
crazynights
Aug 21, 2015 06:53 AM
