5-Speed or 6-Speed?
Old Mar 24, 2001 | 04:28 PM
PhantomTPI's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
5-Speed or 6-Speed?
I was planning on rebuilding my 305 TPI late this summer, and putting some performance parts on it(headers, cam, cold air)...but i was also thinking of getting a manual put in place of my 4 sp OD. Is this a difficult task to do? How should i go about doing this? And what should i go for if i do it...a 5 or 6 speed manual? Any info is apprecitated
1986 5.0 TPI Trans Am
Random Tech Cat
Two Chamber Flowmaster Muffler
Megs Custom 4.5" Stainless Steel Tips
1999 Grand Am GT In-Dash CD Player w/Equalizer(fits like '86 original)
5% Tint On Rear, 35% On Sides
Old Mar 24, 2001 | 09:21 PM
camaro6spd's Avatar
The T-5 5-speed is lighter, much cheaper but less durable then the T-56 6-speed. The T-56 is capable of 450 ft/lbs, has the extea gear but is very heavy and cost mucho dinero!! and it might be overkill for the 305.
-Tom
Old Mar 25, 2001 | 12:28 AM
PhantomTPI's Avatar
Engine: 5.0 TPI
Tom...
If its overkill for the 305, then its a waste. Thanks for saving me lots of $$ and aggravation. I'm not looking(yet) to put out more than 300-350hp. I appreciate the info.
Random Tech Cat
Old Mar 25, 2001 | 08:37 AM
leirch's Avatar
The way i look at it, a 6 speed is more durable, heavier(but who cares?), and the stock t5 is a joke. I don't care what year you get even though the 91-92 WC t-5's were pretty stronger, nothing compares to the t56's. I'm hoping to take my stock t5 out when i get enough money for a t56. My brother has an 88 5.0 mustang(yea i know..sorry) with the stock t5 he has beat the **** out of it in alost 2 years. If you can take it easy on the car, meaning don't drop the clutch and/or speed shift the t5 will hold up pretty well. Again, while your doing all of the mods to your car later this year i can understand you will be strapped for cash so if you could get the t5 cheap that would be another reason to go with it. Plus if you did get the t5 and got it working it would save alot more hassles down the road if and when you wanted a t56.
I know i'm saying alot of contridicting things here but i'm just trying to give all of the +'s and -'s to the t5 and the t56.
Hope that helped,
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
jhawkeye
May 25, 2022 06:33 PM
RedLeader289
Jan 22, 2016 03:05 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
BBSDesigns
Aug 11, 2015 07:39 PM
Dan383T56
Feb 5, 2001 01:54 AM
