another rearend bit the dust!
Old Mar 24, 2001 | 11:03 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Man the darn thing is going out again sound like the pinion bearing is shot. should I go through the trouble of finding a 9 bolt and gears or rebuild this 10 bolt with 3.73s my posi is still good but, I really get sick of the thing breaking on me and like the disk idea. but, I guess If I can destroy so many 10 bolts then the 9 bolt would go to but, just would take longer.
I remember reading that the concept firefox had a dana but, I don't know which one or what had to be done to make it fit.
Old Mar 24, 2001 | 11:15 PM
SUPER-SPORT-CHEVY's Avatar
use a 9 bolt from an S10 same size and much stronger. I have one in my 85, 3:73 and it tough as nails. cost 125$ from junk yard.
85 Camaro RS T tops 350/350, stealth intake. holley street avenger 670. ported 58cc heads. comp magnum 270H cam,Crane 1.6 roller rockers,edelbrock accu-drive, MSD 6 series ignition on HEI, K&N extream air cleaner, true dual exhaust with 18 inch glasspacks.
82 Firebird 305/250 action plus intake, accel distributer with ccs 8mm wires foam air filter.
The only "cat" i have uses the litter box
Old Mar 25, 2001 | 11:32 AM
Engine: ls1, LB9
125 is a great price! what years came with the 9 bolt? does it have disc or drum? does not really matter but, **** would be great being I have drum now
Old Mar 25, 2001 | 10:04 PM
The one i got mine from was an 86 s10 blazer. i have an 85 sitting in the corner just in case my 82 blows a rear end. OS i assume that its 83-present. oh and it is drum. Just measure the lenght to make sure the size is right if you find one and if its from a junk yard dont tell them what your putting it in or they charge you more cause they think its a hot rod item.
Old Mar 25, 2001 | 10:25 PM
Engine: ls1, LB9
Thanks I will start calling. I noticed the yards try to get you for everything they can just afew weeks ago I asked one for 1 window switch for my firebird he said that he wanted 10.00 for one and I would have to pull it and that they go for 20.00 at gm and are also on back order. I told him forget it because I work at the dealership. so I went to parts and ordered two and got them the next day for 14.00 total. man I know I get a deal but, it is only at cost and is next to nothing. I may have to show him the recipt and tell him to start seling things at a used price and I will buy stuff from him. his switch price is above new and they were not on back order.
Old Mar 25, 2001 | 10:45 PM
82camaro's Avatar
Car: 82 camaro SC
1--S10's didn't get the 9 bolt.
2--The gears from an S10 will interchange, but the housing has no provision for a torque arm.
3--The s10 rears aren't any stronger either.
A ford 9 inch would be the strongest.
A GM 12 bolt modified to work in you car would work well. Most cost some $$.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
paul_huryk
Oct 1, 2015 04:27 PM
Zell1luk
Sep 29, 2015 10:36 AM
ndndndnd
Sep 28, 2015 08:00 AM
