NEED HELP - non f-body fwd
Old Mar 24, 2001 | 08:47 PM
Danny P 86Z28's Avatar
This is my beater car, an 89 Olds Cuttlas Ciera with a 3.3 V6 and overdrive auto front wheel drive. I stopped at a stop sign and then I accelerated and it felt like it popped into neutral and the car will not go forward at all. All forward gears do not work but reverse still works. Fluid level is fine. The car has 108k miles on it. Does anybody know what could be the problem?
[This message has been edited by Danny P 86Z28 (edited March 24, 2001).]
Old Mar 24, 2001 | 11:11 PM
SUPER-SPORT-CHEVY's Avatar
usualy that means an expensive rebuild parts for a fwd od cost about 400$ as much a a used transaxle and you would have to pull the trans to fix it. its probably a band or something poped in the valve body. if you step on the gas wot will it move at all?
if so i would check the valve body.
Old Mar 25, 2001 | 01:20 AM
When I hit the gas the engine will rev and the car will slowly creep forward. It does the same thing in all gear positions( OD, D, 2, 1). I have this car a little over a year and several times before when I was driving after stopping I would hit the gas and the engine would rev like it was in neutral for 2 seconds and then slam into 1st. I don't know if this is related to the problem that I have. I have changed the fluid every 15k miles.
Old Mar 25, 2001 | 05:14 PM
I dropped the pan and I did not see any metal chips or anything out of the ordinary. This is really strange.
Old Mar 25, 2001 | 06:01 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Could be a couple of things, all mostly internal. I don't have a clutch and band application chart in front of me for the 4T60, so I can't give you any specific "possible causes", but chances are, its internal.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Mar 25, 2001 | 09:59 PM
Danny, It sounds like its cooked i would just buy a good used one and forget about fixing this one it can be real PITA especially if you rebuild this one and have to take it out again.
Old Mar 26, 2001 | 08:14 PM
I took it to a shop and they tore it down and the band was broken and some other parts were worn out. Now I have to bend over!:O
Old Mar 27, 2001 | 11:40 PM
LOL thats what i was trying to get at its cheaper to buy a good used. well hope this one lasts longer
Old Mar 28, 2001 | 07:26 AM
87formula's Avatar
Sounds to me like the forward cluches are gone, this is not exactly the easiest thing to fix but it is possible, best grab a haynes or chiltons...... Also on a good note your reverse cluck is okay, your pump is okay, and your lo rev cluch is okay.... That is a start.
[This message has been edited by 87formula (edited March 28, 2001).]
gixxer92
Apr 12, 2022 12:09 AM
PurelyPMD
May 5, 2016 04:57 PM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Nervous2
Oct 8, 2015 10:53 PM
