Need Help 83 Z28 bent Mechanical clutch linkage
Old Dec 10, 2008 | 12:43 PM
darkfalcon9112's Avatar
Car: 1983 Z28
Engine: 86 305 (currently preforming swap)
Transmission: Borg Warner T5
Axle/Gears: 3.73 LS
Have Looked everywhere i could think of and the only mechanical linkage's i can find are for 72 through 81. Does anyone know if somehow i can use this, or if there is somewhere where i can purchase one. I believe that it is my z bar that is bent, I cannot fully disengage clutch it will also if ajusted out far enough to barely engage will not fully engage. Any help at all would be appriciated. This is a Daily Driver and I need to fix asap.
Thank you.
Old Dec 11, 2008 | 10:14 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Need Help 83 Z28 bent Mechanical clutch linkage
run down to your local salvage yard and yank the pedal and hydraulics off any '84-'92 Camaro. v6 parts will work.
Old Dec 11, 2008 | 01:30 PM
Car: 1983 Z28
Axle/Gears: 3.73 LS
Did that could not find any full sets in my county.
Ghettobird52
Apr 21, 2020 08:44 PM
Cameeeero
Sep 18, 2015 04:00 PM
19irocz85
Aug 26, 2015 07:54 PM
stalkier
Aug 21, 2015 01:54 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
