Oops!!!, stripped the torque arm mount bolt
Old Mar 28, 2001 | 09:57 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
While installing my trans after a rebuild I stripped the upper torque arm mount bolt. The one that holds the two pieces of metal together and bolts into the trans. I was wondering if a shop would be able to retap this while it's still in the car or will they have to pull the trans. How much will it cost? Thanks.
1986 CAMARO Z28 ->
151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, B&M Ripper shifter, T5 with 3.35 1st gear and 0 miles, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframe connectors, all bushings are urethane, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH 3300lbs less driver and speakers Next mods-> Extreme Energy 268 cam, Holley street dom intake.
1987 TRANS AM ->
73,000 miles, 305TPI, auto, gutted air box.
Old Mar 29, 2001 | 06:55 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
If it stripped out, there probably wont be enough material to re-tap. Use an insert (solid or heli-coil) or just get a fresh tail piece out of the junkyard. pull the speedo gear and 4 bolts and its off (if room is limited it might even be easier to fix it by taking it off anyway)
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
