Weird 700r4 shift thing
Old Dec 13, 2008 | 07:45 PM
townaj's Avatar
Car: 1985 Z/28 Camaro
Engine: 383 baby!!!
Transmission: NWC T5
Ok so my 700r4 is acting kinda weird. When I accelerate hard the transmission will shift out of gear but won't shift up into the next gear. So it stays between gears for a while and the rpm's shoot way up into 5k. I'm thinking this can't be good for the engine. Anybody have an idea as too what is happening? And maybe a fix? I'm putting in a t56 soon hopefully, but I need this tranny to last till then.
Old Dec 13, 2008 | 08:52 PM
Civerus's Avatar
Re: Weird 700r4 shift thing
Classic case of slippage is what it sounds like to me.
Old Dec 13, 2008 | 08:56 PM
townaj's Avatar
Engine: 383 baby!!!
Ok any advice on what I can do about it. I've had the car since September but it hasn't done it until now.
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Sounds like your gonna need your t-56 sooner then you thought.
Old Dec 14, 2008 | 03:41 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
if it is just a classic case of slipping. check your reverse gear, put it in reverse, if its still there and theres no delay in engagement you still have time, reverse is the only mechanical gear, and requires full line pressure for it, so if you ever get a car with a bad reverse(takes a while to kick in) chances are its on its last limps. anyways, give it a flush, most of the time that will take care of it. temporarily that is
Old Dec 14, 2008 | 02:05 PM
townaj's Avatar
Engine: 383 baby!!!
Ya the reverse is good. Ever since I've had the car though it's really jerky when I change gears. Like going from park to reverse or park to drive. Even drive to reverse and vice versa. Is this normal?
Old Dec 14, 2008 | 03:07 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
my 89 rs did the simular to this, a few months later 3rd/2nd/ went. Still had reverse and 1st lol
Does you converter lockup when you put it in OD?
Low trans fluid can cause slipping as well.
Old Dec 15, 2008 | 02:43 AM
sounds like your torque arm bushing, but then again a bad tranny mount can do the same
Old Dec 17, 2008 | 01:39 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
mounts clunk yes. late shift could be t.v. cable came off or t.v. valve stuck. governor valve stuck. mechanical problem like slipping clutches etc. You can check the governor by removing the small round cover on the drivers side with a screwdriver and pull out the governor, check for valve movement. Stuck t.v. much more difficult pull pan and valve body t.v. valve inside valve body likes to stick-aftermarket valves have a spring to help prevent sticking. Checked your trans oil level with engine running in park? could be.. fluid burnt? If burnt (probably is 1984) might be time.
Old Dec 18, 2008 | 06:14 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
When you pull the governor check the plastic gear too, seen a few come apart.
Old Dec 18, 2008 | 10:10 PM
townaj's Avatar
Engine: 383 baby!!!
Ok. Well there's gonna be no car work for a while. Apparently we're moving to Texas. I hate it when my mom does this. I'm pissed so now would not be a good time to mess with a car.
Cleotiz
Jan 6, 2018 08:56 PM
italiano67
Dec 11, 2016 09:21 AM
Bob88GTA
Aug 18, 2015 03:31 PM
TreDeClaw
Aug 14, 2015 06:58 PM
