308 lower than 373?
308 lower than 373?
I have no idea about gear ratios. I don't know what is high or low. My car apparently has 308 gears the engine is a 383 stroker and the trans is a 700R4. It launches hard as hell but runs at about 2200 or 2300 rpm on the enterstate and I wanna get it lower. I was hoping to trade a little low end grunt for mid and high rpm go and better gas mileage on the enterstate. sooooo 373 or something diferent?
Car: 87 GTA
Re: 308 lower than 373?
There is a difference what is termed 'lower gears' and numerically lower gears.
The lower the number, the higher the ratio will be.
3.08 will give you a higher top end, but sacrifice low end launch & vice versa.
If you have 3.08 now, your next step is a 2.73, for interstate mileage. 3.73s will launch you like crazy, but sacrifice mileage even more.
Car: '89 IROC-Z
Engine: LSx
I have 2.73's and my car sits about 19-2000 rpms at 70, I hate how doggy they are so I'm swapping in 3.42's. I never thought higher than 2.73's existed, then I saw a mid 80's vette with 2.56's. Thats insane.
Well I know next to nothing about gear ratios, but I had an 85 vette. Don't know what gears it had but it launched pretty hard.
Thanks a lot for all the advice guys. I apreciate it.
Car: 87 GTA
What it amounts to is....
Numerically higher (like 3.73) equals being called "lower" gears...Numerically lower (like 3.08) is caller "higher" or "taller".
So...3.08 is "lower" than a 2.73, but "higher" than a 3.73. It is all relative between the 2 gear ratios your comparing.
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
What year is your car?
with my tires (about 27" diameter) and stock '85 700r4 and 3.08 gears, I do about 1900 RPM at 70 mph.
How many mph are you going when your doing 2200-2300 RPM?
You might want to check the accuracy of your tachometer.
