Will It Work???
Old Dec 17, 2008 | 02:03 PM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
Will It Work???
Alrite well ive got a 89 RS and a wrecked 87 Iroc. The RS is a T-5 car and the Iroc, is a 700R4 car, would it be possible to use the Iroc motor, but mate it up with the T-5, using all of the TPI computer and everything. I know ill have to get a new clutch and flywheel, but will i have any computer problems, mounting problems, wat do i need?!?! please help me.
Old Dec 17, 2008 | 03:26 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Will It Work???
Transplants are always an opportunity to deal with and learn from the experience. You're lucky to have both vehicles! That's to your advantage because, you will be swapping stuff.... Hopefully, you wont have any issues. Your car vintages are compatible, so have at it if you dare.
Here's a link to a web site that you might find helpful? Good luck, it's your mission, should you choose to accept it.
http://www.chevythunder.com
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
