5 speed swap
5 speed swap
In the tech section I saw the article on swaping a 5 speed into an auto car. It didn't mention anything about replacing the radiator. I know that metal lines run from the radiator to the trans, wouldn't I have to change that as well? I'm trying to decide wether to swap in a 5 speed or do something with my automatic.
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Re: 5 speed swap
The 5-speed swap is pretty straight forward, but a lot of work. There are a few articles on this board so check it out. If you find a donor car with all the parts you need that will help a lot.
1992 Trans Am
Aug 8, 2015 08:16 PM
