10 Bolt buildup- some questions! PLEASE step inside!
Old Apr 4, 2001 | 08:47 AM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
Ok, here's the deal, gettin a 350, puts 430 out at the crank... motors been DYNOED at this.
i have an 86 firebird, and i want to upgrade the rear...
1- it has 26 spline axels, i plan on upgrading to the 28's
2- which posi?? slp has 2- the hd zexel, and the reg one- i plan on runnin 255 toyo's on the back, and prob not stickies on this rear. will the 75 buck oem posi from slp hold 400horse?
3- what brand gears? i ike richmonds, but hear people have trouble with em...
basically, i am on a budget for now, the motor swap is hurting, but i gotta do a bit for the rear till i have money to put a 9inch or a 12 bolt in.
thanx in advance guys!
Steve
Old Apr 4, 2001 | 06:38 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I recommend a rear diff cover like this one, cheap insurance for a 10 bolt.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Apr 4, 2001 | 06:39 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Whats w/ all the red, man?
I don't see "raptor home grown" in your sig either! Hahahahaaa
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
[This message has been edited by GMTech (edited April 04, 2001).]
Old Apr 4, 2001 | 06:58 PM
fb305svs's Avatar
hey john- where can you get a cover like that and how much are they? is it called a rear end girdle? anyways, you think that the oem posi is gonna hold?? it will see plenty of street racing on reg radials, and some track time, possibly slicks.... i also plan on welding the axel tubes as well
Steve
Old Apr 4, 2001 | 07:20 PM
82camaro's Avatar
Car: 82 camaro SC
If you run slicks with that much power, you will reduce the life of your diff big time.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Apr 4, 2001 | 07:45 PM
Engine: 4.0L
<font face="Verdana, Arial" size="2">Originally posted by fb305svs:
Steve
</font>
I got it from Summit for about $130, it is a very nice piece and has held up to my stroker TPI for the past year now. I believe the stock posi will be fine, I orginally had a peg leg open rear and bought an Auburn pro posi as an upgrade. The girdle is insurance.
Old Apr 4, 2001 | 09:19 PM
fb305svs's Avatar
kool- hey how exactly does it work? (the girdle)
Steve
Old Apr 4, 2001 | 09:42 PM
Engine: 4.0L
Well, it's at least 1/2" thick just like the rest of the rear housing so that it spreads the load evenly around the case. Second, it has thrust bolts that apply pressure againest the main bearing caps to prevent any flexing of the carrier, this prevents breakage inside.
86 Camaro Sport
My Camaro Project
Old Apr 5, 2001 | 05:28 AM
Engine: 4.0L
<font face="Verdana, Arial" size="2">Originally posted by GMTech:
</font>
The panhard bar and LCA's are powercoated red from Hotchkis, NOT my doing. The sway bar...it just seemed right with the other red around. You should see the front!
86 Camaro Sport
My Camaro Project
Old Apr 5, 2001 | 05:56 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I'm just teasin' John. Since your car would run circles around mine, I have very little to rag you about.
But back to the topic:
I think the Richmond gears will be OK, you just have to make sure you break them in. If you don't, you can cause the gears to lose their heat treating and become weak.
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
--&gt;14.97 @ 94.9 MPH&lt;--
'97 Bonneville SSE
Old Apr 5, 2001 | 08:09 AM
fb305svs's Avatar
hmmm and now which posi... 74.95, or 299.99
grrrr
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
redmaroz
Aug 16, 2015 11:40 PM
