Need Help with Drive gear and Driven gear!!!!!
Old Dec 22, 2008 | 07:18 PM
MAG85Z28's Avatar
Car: 1985 Z28 Camaro
Engine: 5.7
Transmission: 700r
So i bought this project 85 z28 camaro 4 months ago and found out the speedo was off "about" 15 mph give or take!!!! So first i took the Rear end cover off and found stamped on the rear end that it was a 3.27... Now i went under the car and Seen that the drivin gear is RED with 37 teeth and the drive gear was light blue with 18 teeth on it... Is there any way to just change the drivin gear and not the drive gear without Screwing anything up??? My tire size is a 245/50/16 as well... I am New at this so i am not sure if i can just buy a bigger or smaller drivin gear to change it or do i have to get both???
PLEASE SOMEONE HELP!!!!!!!!!!
Old Dec 22, 2008 | 07:30 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Need Help with Drive gear and Drivin gear!!!!!
red and lt blue is correct for 3.27 and 245/50/16 you got another problem, wait never mind you need a red drive and a lt blue driven seems like someone got confused and ordered the driven and driven mixed up in color since you got a lt blue drive and a red driven
http://www.transmissioncenter.net/speedometer_calibration_______va.htm
http://www.3rdgenformula.com/87/speedometer_gears.htm
https://www.thirdgen.org/forums/transmissions-drivetrain/442105-choosing-right-speedometer-gear.html
Old Dec 23, 2008 | 07:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Need Help with Drive gear and Driven gear!!!!!
Mag,
Off topic: I assume you've swapped a 5.7 into your car since that wasn't an option in 85.
JamesC
Old Dec 23, 2008 | 12:02 PM
MAG85Z28's Avatar
Engine: 5.7
Transmission: 700r
JamesC
You are Correct with the 5.7... Here is a Pic of the Motor if you would like to see..... Name:  Picture020.jpg
Vintageracer
Jan 10, 2020 05:33 PM
jklein337
Sep 19, 2018 06:23 PM
69 Six Pack
Oct 5, 2015 07:51 PM
