v6 700 to v8
Old Dec 25, 2008 | 07:48 PM
RedHawkLB9's Avatar
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
v6 700 to v8
will a 700r from a v6 bolt up to a v8 thx
Old Dec 25, 2008 | 11:11 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Re: v6 700 to v8
No, they use a 60* bellhousing, smallblocks use a 90*.
Old Dec 27, 2008 | 05:58 PM
Sevarg710X's Avatar
Car: 1990 Iroc-Z
Engine: 360 c.i.d
Transmission: WC t-5
Re: v6 700 to v8
you couldn't just change the bellhousing ?
Old Dec 27, 2008 | 06:30 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: v6 700 to v8
700r4 dont have modular bellhousings, the case is one piece, u need a v8 stlye 700r4 the only exception is a 700r4 that was behind a 4.3v6 like in a blazer or truck those have v8 bellhousing patterns.....if u get one of those all u have to do is swap the tail shaft housing wich is 4 bolts and a 99 cent gasket....
Old Dec 27, 2008 | 06:37 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: v6 700 to v8
depends on what the v6 trans. is from.
If its from a 2.8 or 3.1 engine then no,it will absolutely not work.
However,if the v6 trans. in question is from a 4.3 engine,then yes it will bolt up just fine to a v8.
Old Dec 27, 2008 | 07:06 PM
jonarotz's Avatar
Car: 91 Z28
Re: v6 700 to v8
There is a a difference in the 3/4 clutch pack though. The V6's have less clutches which mean it wouldn't be as strong.
86IROC112
Nov 27, 2015 09:54 AM
armybyrd
Oct 24, 2015 06:59 AM
84 TA NV
Sep 6, 2015 08:02 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
