broken ring gear bolts?
Old Dec 26, 2008 | 12:54 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
i had this problem about 8 months ago where like 4 ring gear bolts came lose and broke. so i replaced all the bolts and used loctite on them. on tue i was driving along when all of a sudden BANG and then the back wheels just locked up! anyways all the ring gear bolts broke and a few wedged themselves between the carier and housing with one that punctured the housing!
i am wonder if anyone has any ideas as to why these bolts keep coming lose?
Thanks, Ted
Old Dec 26, 2008 | 01:06 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: broken ring gear bolts?
Thanks, Ted
IDK, i just had my pinion gear break, and go through the housing, so i feel your pain.....got a rear end from a friend to put in mine, and they guy who is rebuilding it for me said the ring bolts were so tight 2 broke off tring to take them out.....you may want to see if they have split locks for the ring gear
here is a set for a dizzy hold down
http://www.jegs.com/i/Breslin/154/200-106/10002/-1
may want to look into something like that
Old Dec 26, 2008 | 02:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Ring gear bolts should not have lock washers but should have red Loctite and be torqued. Over tightening the bolts causes them to stretch.
I believe GM ring gear bolts are left hand thread so you need a torque wrench that can torque LH thread bolts.
Although factory fasteners are fine, I'd recommend an aftermarket fastener such as ARP.
Old Dec 26, 2008 | 08:16 PM
big gear head's Avatar
Need some more information. Which rear end is this, are you using a ring gear spacer, are the bolts GM or after market? I've had similar problems before, but I need to know what you have. There are several things that can cause this.
Old Jan 2, 2009 | 09:20 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
sorry for the late reply!
its a 7.5 10 bolt with an auburn posi and 3.73 richmond gears with a spacer and also moser 28 spline axles. the whole unit was profesionaly assy. and loctite was used
Old Jan 3, 2009 | 03:34 AM
I was pretty sure that you were going to say that there was a spacer. This is common with ring gear spacers and just another reason not to use one. I've seen it many times.
Notice that ALL of the bolts are broke in this one. This is a 12 bolt with a spacer. Click on the picture for a better view.
Old Jan 7, 2009 | 03:36 AM
Pat Hall's Avatar
Most experienced rearend builders will tell you to avoid ring gear spacers. Most spacers are poorly machined (i.e. the bolt holes in them are bigger in diameter than the ring gear bolts). This causes the ring gear to move and slip enough to shear the bolts when enough torque is applied to the rearend. Some people even end up using the standard length ring gear bolts with a spacer, which is another disaster waiting to happen. If you need to run a 3 series gear with a 2 series carrier, the better option by far is to buy the "thick" gearset. The ring gear is machined thicker so it'll work with a 2 series carrier while eliminating the need for a spacer ring.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
