V6 hydro setup the same as V8 T5 hydro?
Old Dec 26, 2008 | 04:40 PM
87SSTPI's Avatar
Car: 1987 Monte Carlo SS
Engine: Vortec headed 350
Transmission: '89 WC T5
Is the V6 hydro setup on the 3rd gens the same as the V8 hydro setups? Or are they different?
Thanks in advance for any info.
BTW, I did try searching but couldn't find any info.
Old Dec 26, 2008 | 04:57 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: V6 hydro setup the same as V8 T5 hydro?
I'm assuming you're talking about a hydraulic clutch?
The master and slave should be the same
Old Dec 26, 2008 | 05:16 PM
87SSTPI's Avatar
Thanks.
Yes, I was meaning the hydro clutch (T5) setups.
Old Dec 28, 2008 | 09:54 AM
Pat Hall's Avatar
Stephen's reply is correct. You will need to get a V8 bellhousing and release fork though. You can see the difference between the two bellhousings at a glance, and even though the release forks look similar, the V6 one supposedly has a different throw/angle, along with a different part #.
Old Dec 28, 2008 | 12:03 PM
87SSTPI's Avatar
Thanks. I was looking at possibly buying the master/slave/and hose assembly from a V6 T5 just for a spare and didn't know if they were the same as the V8 ones. The one I was looking at has already sold as a complete T5 swap, but I was just showing interest in case the seller ended up selling some of the components seperate.
Again, thanks for the info though, since now I will know
Daz
Dec 14, 2003 05:03 PM
ES87iroc
Sep 25, 2003 08:14 PM
Rippin92RS
Jun 25, 2003 04:22 PM
vwdave
Feb 23, 2003 02:40 PM
