I want my rearend to jump sideways when i take off, what do i need
Old Apr 6, 2001 | 08:40 PM
it3's Avatar
it3
Im a newbie, and have pretty much no mechanical experience, so...
I see these car's all over my town, and when they take off, there rearends kick to the right or left a little..
What would I need to make mine do the same?
I have a 305 TBI, 700R4 auto..no shiftkit..
I own a shift kit, but it isn't installed.
It's a "TransGo NoYoYo SysKoKal" system correction and calibration kit. Would that help performance, or would it just correxct slippage, which I don't have?
Old Apr 6, 2001 | 09:29 PM
SUPER-SPORT-CHEVY's Avatar
Its not a trick rearend its pure torque!
One tire will hook up and pull the back of the car in that direction while the ohter tire spins. A strait launch is more desireable unless you want to show off
Old Apr 6, 2001 | 10:01 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
just a little bit of physics here...start paying attention to which direction they're kicking out. you'll notice that they ALWAYS go to the right. unless they are doing a burnout in reverse
when your tires are spinning (both of them) the rotational acceleration of the wheels, commonly misphrased as "centrifugal acceleration" yeilds a force to the LEFT. this force acts on the ground...equal and opposite...car kicks to the RIGHT!
class adjourned
Clem
BTW, SSC is right, lots of torque and a posi. the key is to spin BOTH tires at the same time!
Clem
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission---FOR SALE---
Looking for a V8, preferably 4 or 5 speed Camaro with NO T-tops (wanna trade?)
Old Apr 6, 2001 | 10:03 PM
it3's Avatar
it3
Can someone please answermy question?
What is the best mod to do to my engine to get the most hp, and torque? Thanks
Old Apr 7, 2001 | 01:37 AM
RARE-ROC-Z's Avatar
supercharger will give you the most HP and TQ. but that will also run you about 3000.00 plus you will have to install some gears and a posi that rear end so you dont kill your right hand rear tire!. have fun man, and DONT KILL YOURSELF.
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 7.5" 10 Bolt 3.23gears
Bright Red Hardtop/ Grey Custom Interior
5,507 IROC's Hardtops/Ttops; 2,415 5.7L IROC's Produced in 1990
DAILY DRIVER: 1991 S10 2.5L/5SPD WITH CAMARO RIMS
Old Apr 7, 2001 | 10:20 AM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
hey,
put in lower gears and a posi. then pull your heads and have them ported and polished. nitrous maybe???
Clem
Old Apr 7, 2001 | 01:58 PM
Not to sound like an A**hole, But do you know how to power brake? Your setup should at least spin the tires to 20!
The cheapst mod is a cam swap dont go over 220@.50 that could be bad unless you do other mods.
Old Apr 7, 2001 | 06:35 PM
it3's Avatar
it3
Yes, I know how to powerbrake. I have bounced my rearend off a curb sideways from about 6 feet away while powerbraking, (not that I meant to)
I have read that a cam was the best mod, especially in the 305. If I took it to a garage, how much do you think it would cost?
Or where do you all think it would be the cheapest place to get a cam swapped?
Old Apr 7, 2001 | 07:51 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
a camshaft change is going to cut down low end torque,making it harder to spin tires
Old Apr 7, 2001 | 09:44 PM
<font face="Verdana, Arial" size="2">Originally posted by zenish:
a camshaft change is going to cut down low end torque,making it harder to spin tires</font>
Not necessarily! thats why i said go below 220 it3, you should have a roller cam as "OE" just get a replacement +1 or RV some rv cams besdies giving more power actually improve gas mileage. its about 180$ for a roller cam"not including new roller lifters" and about 140$ for a good melling cam including new lifters and pushrods. you can get more cam profiles if you loose the roller cam. a cam instalation should take a mechanic about 6 hours so 500$ should be max for a cam & instalation.
Old Apr 8, 2001 | 02:22 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Why in GOD's name would you ever find a reason to lose a roller cam (unless going to a solid roller?)
Seems like a backasswards confrragglement to me.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
RS Reaper
Oct 17, 2018 07:52 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
RedLeader289
Sep 23, 2015 06:50 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
