84 Camaro, Want a Torque Converter - How do I know if I have a 27-spline or 30-spline
Old Apr 4, 2001 | 10:59 PM
CamaroX84's Avatar
I was looking at the Summit catalog at the torque converters. For our TH-700R-4 transmissions, they are divided into 1982-84 (27-spline) and 1984-91 (30-spline). Since I have an 84, how do I know which one to order? I am putting in a new engine soon, and I want to order my torque converter first. What are they talking about when they say splines? In other words, what has 27 or 30 splines? Any help is greatly appreciated. Thanks.
1984 Camaro Sport Coupe - 73K Miles
5.0 Carbed LG4
COMPLETELY stock except for a K&N Air Filter
F41 Suspension Package
700R4 Tranny
3.08 Rear End
New Paint
Best 1/4 Mile Run:
16.760 @ 80.74 MPH
Coming Soon:
350 TPI
Complete 3" Exhaust System
Aluminum Drive Shaft
3.27 Disc Brake Posi Rear
Old Apr 4, 2001 | 11:16 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It refers to the size of the input shaft on the transmission that the torque converter has to mate with. A spline is a groove almost like a gear tooth. The more splines a shaft has the larger it is.
As far as telling which you have, someone might be able to tell you from the numbers on your transmission.
Old Apr 8, 2001 | 12:13 AM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
You'll probably have to count them to know for sure. 84 was the year that gm changed from 27 to 30. My 84 Z-28 had 30 but my buddys had a 27. You might be able to find out something from the numbers on the trans. Anyway good luck!
Old Apr 8, 2001 | 12:37 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
so GM went with a 30 spline in 1984?can any one else comfirm this?
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://photos.yahoo.com/tonysams72
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation/
Old Apr 8, 2001 | 02:16 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
It was a carry-over year. Just like with the aux valve body 700r4's in 1987. Some had it, some didn't. You have to check to be sure otherwise it's a gamble. You may have either spline count.
Old Apr 8, 2001 | 04:07 AM
Pro Built Automatics's Avatar
The Outer Diameter on the 27 spline is apx .890 & the 30 is apx .990. If you have calipers or micrometer this is the faster way to do it.
Hope This Helps!!!
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
InfinityShade
Aug 22, 2015 08:00 PM
gwade12
Aug 8, 2015 08:17 AM
