'85 IROC 700R4 "jerks"
Old Apr 8, 2001 | 07:58 PM
Keith5's Avatar
Car: C1500
When I put it in gear it "jerks" hard, the engine stubbles, then it as the engine recovers the back wheels will spin sometimes.
It doesn't do it as bad in reverse, and is even normal going into reverse sometimes.
I've adjusted the T/V cable it did nothing to change it.
Is it tranny time? If so I might use this one the rest of the way up and put in a T5 or T56. Probably T-5 because of budget.
1989 Pontiac Firebird Formula LO3 Auto
-180 degree stat
-Hooker Cat-Back
velcro t-top bag
*****Possible summer '01 mods*****
Dual Snorkle, Keyless Entry, Wonder Bar from my IROC, 4th gen seats, T/A tail lights
1985 IROC-Z, TPI Auto
-Accel Super Coil
http://www.geocities.com/krt80/
Old Apr 8, 2001 | 08:42 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Is your idle too high?
Old Apr 8, 2001 | 08:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Early 700's are pretty well-known for this, later ones had an accumulator to soften the initial shift into gear. If your tires are slipping, your rear brakes probably need adjusting too.
Old Apr 8, 2001 | 09:32 PM
Keith5's Avatar
Car: C1500
I put new brakes on it last summer after I got it, it isn't the brakes. It has done this since I got it, haven't drove it much. Before I put the new rear brakes on, it would spin on pavement, now just grass and gravel.
One thing about the brakes though, they were factory rear disc, I found that in the RPO codes. Now they are Drum, were when I got the car. Maybe they didn't put in the right proportioning valve or something. I still don't think that would cause this though. This is a hard jerk.
And the idle is a little high but that shouldn't make it do this. I can put my Formula in gear in morning high idle at like 1500rpm, it goes into gear nice and easy.
[This message has been edited by Keith5 (edited April 08, 2001).]
Old Apr 8, 2001 | 10:23 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Your 89 will probably have the 87 1/2 and later 700R4 with the accumulator in the auxiliary valve body.
Old Apr 9, 2001 | 12:02 AM
bullfrawg's Avatar
When you put it into drive push your brakes harder. If it still spins your rear wheels your brakes probably need adjusted. Remember my TA jerks really bad.
Old Apr 9, 2001 | 08:00 AM
Keith5's Avatar
Car: C1500
Even if my wheels don't spin, it "jerks" so bad that it makes a loud clunk.
Old Apr 9, 2001 | 08:25 AM
IROCketZ28's Avatar
Have you checked your tranny mount? It may seem obvious, but the obvious is often overlooked If the mount is bad, it will cause a "clunk" when you put it in gear, and will make the car jerk. I've never personally seen one that caused the tires to chirp though, but hey, anything's possible, right? Let us know...
'87 IROC Z28
TPI 305
5-speed w/ Centerforce clutch
3 1/2" exhaust w/ Flowmaster
Clarion, Kenwood, Eclipse, Polk, MTX, Autotek 800 watt stereo system
Grant wheel
Otherwise stock, & good for a 14.68 at DeSoto Dragstrip
More to come soon...
Shooting for high 13's with bolt-on's
Old Apr 9, 2001 | 08:33 AM
Keith5's Avatar
Car: C1500
I looked at it last summer. It looked alright.
Oh one more thing. When I drove it, the transmission seem to get hot, I could feel it on the floor around the console.
Old Apr 9, 2001 | 08:13 PM
bullfrawg's Avatar
I thought last summer you said that two crossmember bolts were loose and one other was stripped and you thought you had fixed it. Maybe they have come loose again
Old Apr 9, 2001 | 10:25 PM
Keith5's Avatar
Car: C1500
I thought that might be it. So about a week ago I put a jack under the crossmember and put some pressure on it so it couldn't drop if the bolts have come loose again. It still jerked.
BlueIroc-Z
Jun 9, 2019 03:22 AM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Leggman1
Aug 6, 2015 04:15 AM
