If one is good... will 2 be better? Tranny cooler idea help -->
Old Apr 9, 2001 | 02:36 PM
Biochem's Avatar
Car: 2002 SOM z28
I just got a Griffin radiator for a good price off a friend, and I needed a new radiator before summer hit again (it's 92F out today :eek .
Right now, I have a medium size tranny cooler in-line with the stock cooler (which I assume is that radiator in front of my stock one). Even with my 3000 stall, I rarily see above 150-170F fluid temps. But with this new radiator, I will not have enough room to run it and the stock tranny cooler. I do have another med-large aftermarket cooler which is larger then the one I run now along with the stock cooler.
Should I run both aftermarket tranny coolers, or just the bigger one?
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Apr 9, 2001 | 03:28 PM
82camaro's Avatar
Car: 82 camaro SC
Not sure on your post, but the stock cooler is built into the radiator(you can't see it). Are you talking about the AC condenser? Does your new radiator have a built in tranny cooler(it will if it is for a automatic car)?
I would run one big cooler rather than 2 small ones because of the additional rubber hoses(more stuff to leak/break).
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Apr 9, 2001 | 04:09 PM
Biochem's Avatar
Car: 2002 SOM z28
Yeah, looking at it now, it does run in to the radiator. The new radiator is only for coolent.
If I ditch the AC... I shouldn't need the radiator-like thing in front of the coolent radiator, right?
Old Apr 9, 2001 | 04:34 PM
82camaro's Avatar
Car: 82 camaro SC
Yes if you ditch the AC you will have more room. A good, large aftermarket tranny cooler should work OK for you. I've seen people use the ac condenser as the tranny cooler by hooking the tranny lines to it. I doubt it would cool as good as a tranny cooler though.
82camaro
Old Apr 9, 2001 | 07:11 PM
Biochem's Avatar
Car: 2002 SOM z28
It is a good size cooler. It has about 1/2" tube that winds back and forth about 4 times with fins (like the radiator). The other one I have now has about 6 flat tubes that are about 1" wide and all start/finish from the same hole.
Old Apr 10, 2001 | 03:17 AM
tpsierra's Avatar
Believe it or not, the tranny cooler is acturally primarially (sp) a tranny fluid heater! GM cars are set to run water to the heater core first, then by the tranny fluid cooler lines so the fluid gets warmed up faster. Tranny fluid is a lousy lubricant at low temperatures, you do not want the fluid too cool, don't over do it!
1957 3/4 rat
1966 c10 panel
1968 c20 350, 350
1982 camaro 305, THM-200-R4
1984 Monte Carlo, 350, th-350
Everett, WA
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Jetmeck
Sep 4, 2015 12:29 AM
andy74
Sep 3, 2015 08:41 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
