No lock-up??, need help...FAST!
Old Apr 12, 2001 | 08:44 PM
1986TransAm's Avatar
I'm not sure of which forum to put this in, carbs or tranny, so I'll put it up in both.
Anyway, I recently swapped my computer-controlled q-jet, for a non-computer controlled Edelbrock #1405. I also swapped in a rebuilt non computer-controlled HEI distributor. It's a vac. advance set up.
The car runs great, however, my torque converter lock-up isn't working now due to the lack of ECM controll. How do I fix this??? Any help would be great..
P.S.- It's a 700r4 tranny..
Old Apr 12, 2001 | 10:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Several companies make a kit with everything you need to make the converter lock up again. I like TCI's best, P/N 376600, you can get it at Summit or Jeg's.
Old Apr 13, 2001 | 10:02 AM
Remondi2's Avatar
I'm looking into controling my 700r4 w/o a ecm also. What makes you perfer this kit? Has anyone had any experence with the gm kit (p.n.24502513)? Just weighing my options, thanks.
Old Apr 13, 2001 | 02:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The TCI kit comes with a vaccuum switch and 4th gear switch, which is all you really need for this application. It also comes with the 4 pin switch and some wiring.
The Painless Wiring kit comes with vaccuum switch, 4th gear switch, TCC solenoid, brake pedal switch and some wiring. The Painless kit is a little more complete for putting into a car that's never had a 700R4, but for an F-body you're just paying for more things you don't need.
B&M also makes a kit which I don't like for 2 reasons:
1. It makes lockup speed dependent and not demand dependend.
2. It's made by B&M.
The GM kit is for putting a replacement 4L60 into a car that originally came with a 700R4, it doesn't really have what you need.
Old Apr 13, 2001 | 04:08 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If you want to make the lockup switch yourself:
http://www.thegrid.net/thedrivetrainpage/700inst.htm
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Nick McCardle
Sep 10, 2015 08:36 PM
Chris's 85z
Apr 25, 2003 06:51 PM
Lurch
Carburetors
Jun 11, 2002 08:27 AM
