terrible shaking while engaging clutch
Old Apr 14, 2001 | 11:11 PM
bullfrawg's Avatar
I just dropped in my 305HO I replaced the old clutch and pressure plate and throwout bearing. The motor seems to run fine. When i let the clutch out it will jerk horribly, as if the cars brakes are locked or something and i have to go to about 2200 rpms while letting it out to keep it from dying. Once it is fully out it seems to go fine. Before i swaped the motor and clutch it was as smooth as could be. What could be my problem.
1985 TransAm BLK/GLD Stock
1985 TransAm BLK/BLK
305HO (soon as it is put in) 5-speed, 3.27 posi, WS6, power everthing.
http://www.geocities.com/bullfrawgs
Old Apr 15, 2001 | 09:08 AM
ede's Avatar
ede
i'm pretty sure you can't get the disk in backwards on them. did you resurface the flywheel? change the throw out bearing? no air in the hydrolics?
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 15, 2001 | 04:59 PM
bullfrawg's Avatar
The clutch i put in was the 10.4" and the one that came out was a 10.4" The flywheel seemed smooth so i didn't resurface it. Do you think it could be warped or something? I did change the throwout bearing. I don't think there is air in the line but i will check to be sure.
InfernalVortex
Apr 20, 2021 11:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianI
Oct 3, 2015 12:57 PM
Eric-86sc
Sep 28, 2015 11:37 AM
mfp189
Sep 27, 2015 09:25 AM
