Rattling & vibration problems in drivetrain when at a stop
Old Apr 15, 2001 | 12:01 AM
CAMARORS1991's Avatar
For a while now my 91 RS has had a rattling problem in either the drive shaft or transmission. The trasmission was just rebuilt and the rear u-joint was replaced. Every time I am in gear and at a stop the drive shaft rattles really bad. Its not constant though, it will rattle for a second or so, then stop, then do it again until I start moving. It only does it in gear, it is fine in park and neutral. Any suggestions??
Old Apr 15, 2001 | 03:06 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
It maybe your converter bracket. it is attached to the tail shaft of your trans. very common problem.
Old Apr 15, 2001 | 03:45 PM
Is this something that can be easily tightened or fixed?? Can I do it or do I need to take it back to the shop that rebuilt the tranny??
Old Apr 15, 2001 | 05:28 PM
Engine: ls1, LB9
you can fix it. it is just ametal braket at the end of the trans make sure it is tight at the trans and where it ataches to your converter
toones
Jan 6, 2016 06:00 PM
aaron7
Aug 26, 2015 09:45 AM
db057
Aug 22, 2015 08:17 PM
mustangman65_79
Aug 8, 2015 12:07 PM
